09-01-2022, 02:18 PM | #1 |
34 with 15" wheels
Not sure what to buy. 15" wire wheels on a 34 victoria 4" drop axel.
wheels are 5.3/8 wide. I would like radial tires . questions: #1 can I run radials with tubes ? #2 what is the smallest tire I can run (front ) #3 what would a good size for rear ( big and small ) this 34 has 289 ford - C4 - 8" full fenders Thank you for any help |
09-01-2022, 04:20 PM | #2 |
Re: 34 with 15" wheels
Is it 5 3/8" wide across, from inner bead to inner bead ?
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
09-01-2022, 04:27 PM | #3 |
yes
09-01-2022, 05:54 PM | #4 |
Prolly 195-70-15 front
Prolly 225-70-15 rear .
09-01-2022, 07:05 PM | #5 |
Radials are good - but you don't need tubes if it's regular (non spoke) wheel. If the wheel is welded spokes (to the rim), you don't need a tube either.
If the wheels are not welded spokes, then a liner and tubes are usually required. Get tubes that are made for radials.
09-02-2022, 05:22 AM | #6 |
09-02-2022, 06:50 AM | #7 |
Nick,
P195 70R 15 Front P225 70R 15 Rear Is what I have on my car, without tubes. |
