07-13-2018, 01:03 PM | #1 |
new rubber seals on 41 ford vent wing wondows
What is the best way to install the vent wing rubber seals on my 1941 ford coupe. I have removed the right side seal and am having hell getting the new one back in, Any suggestions, need help. Al
07-13-2018, 01:15 PM | #2 |
Re: new rubber seals on 41 ford vent wing wondows
I worked around mine using a small stubby flat blade screwdriver. A bit of CRC/wd40 helps it go in. Some people use dish wash liquid but the water content can cause rust to eventually form in the channel under the rubber.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-13-2018, 07:13 PM | #3 |
