Old 07-06-2018, 05:41 PM   #21
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Adjusting Camber, looking for a shop in Connecticut.
Originally Posted by 34PKUP View Post
Just wondering who said anything about heating a cast axle??
Re-read TJ's post #16 (which I quoted).....highly-suggestive! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-06-2018, 08:25 PM   #22
JSeery
JSeery's Avatar
An orginal is forged and can be bent.
Old 07-09-2018, 10:31 AM   #23
revkev6
you can also call ferrara springs in springfield mass. they do alignments and custom springs.
revkev6 is offline   Reply With Quote
Old 07-09-2018, 03:36 PM   #24
DocJohn
Hi, are you using radial or bias ply tyres? If you are using radials then you may not need to alter the camber. The original Ford spec is for bias ply tyres and radials tend to prefer a bit more negative camber.
DocJohn is offline   Reply With Quote
Old 07-09-2018, 04:13 PM   #25
Bursonaw
Bursonaw's Avatar
Right now I’m running bias ply tires. I will be switching over to radials this fall.
Bursonaw is offline   Reply With Quote
Old 07-10-2018, 03:42 PM   #26
DocJohn
Maybe leave it until you've tried it with the radials? You may like the way it drives. You'll have a bit of experimenting to do with tyre pressures anyway.
Old 07-10-2018, 09:00 PM   #27
Bursonaw
Bursonaw's Avatar
It’s out of original spec from Ford and I can see where it is wearing the inside of the tires. So it does need adjustment.
Sent from my iPad using Tapatalk
Old 07-10-2018, 11:04 PM   #28
fordor41
fordor41's Avatar
wearing insides. sounds like too much toe out
fordor41 is offline   Reply With Quote
Old 07-11-2018, 12:37 PM   #29
Bursonaw
Bursonaw's Avatar
Update:
Superior Spring did a great job with adjusting everything into spec. They had to cold bend the axle to bring the camber in. It was at -3/4” now it’s +1/4”. Caster and Toe were checked and no adjustment was required.
Thanks to those who recommended them. They do quite a few hot rods and classic cars. The tech who worked on my car had been doing these type of alignments for 30+ years.
Regards.
Old 07-11-2018, 12:45 PM   #30
JSeery
JSeery's Avatar
Good update information!
