07-03-2018, 05:04 PM | #1 |
Adjusting Camber, looking for a shop in Connecticut.
I had just checked the alignment on my 36 Ford. I’m running a 4” dropped axle, the total Camber measured at negative 1 degrees. The Ford specks are 0 to 1 degree positive.
My choices to correct the camber are. 1. Remove the axle and send it out for adjustment. 2. Find a local shop that will cold bend the axle on the car. A common procedure many years ago, however after many calls, it seams to be a lost art. I did call some diesel truck shops but I was told that the alignment rack is to big for my car. Before I go with option 1, Does anyone know a shop in New England that can cold bend an axle on the car? Sent from my iPad using Tapatalk |
07-03-2018, 06:50 PM | #2 | |
Re: Adjusting Camber, looking for a shop in Connecticut.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-03-2018, 06:54 PM | #3 | |
Thanks I will try them! Regards Tony Sent from my iPad using Tapatalk |
07-03-2018, 07:09 PM | #4 | |
What city are they in? There are three listed, Hartford, CT. Hamden, CT and Cheshire, MA. Regards Tony Sent from my iPad using Tapatalk |
07-03-2018, 09:03 PM | #5 |
Used Superior Spring in Hartford years ago but I believe they are no longer in business on West Service Rd. in Htfd.
Super Spring, I believe is a spin off and took over some of the business when Superior left. Call Super Spring to see if they can provide the service. Also try Strongs Alighnment They aligned my car. http://www.strongsalignment.com/
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 07-03-2018 at 09:22 PM. |
07-03-2018, 09:05 PM | #6 | |
I will check them out, thanks! Tony Sent from my iPad using Tapatalk |
07-03-2018, 09:35 PM | #7 |
Go to the Hartford location since thats closer to you. My axle issues were corrected at the Hamden location.
07-03-2018, 10:13 PM | #8 |
There was a discussion last week about big and little tires effect on camber.
Bruce
Works good Lasts long time |
07-03-2018, 10:21 PM | #9 |
07-04-2018, 06:43 AM | #10 |
Camber is an important issue with handling and tire wear. A good way to check it is with a yellow tire crayon. Find a long straight flat surface (parking lot). Put several horizontal lines across the tire and go for a ride. don't make any turns. This should show even wear pattern.
07-04-2018, 06:47 AM | #11 |
There's also a truck alignment shop on Rte 5 (John Fitch Blvd) north of the 291 exit for 5, it's on the left. I forget the name.
Had many things done at Superior years and years ago. Super Spring should be able to help you as others have said. Paul in CT |
07-05-2018, 02:39 PM | #12 |
I want to thank everyone that replied to this post and update them on my progress.
I called Super Spring in Hartford and they do not adjust straight axles. I then called Superior Spring in Hamden and they were the only ones that I could find in Connecticut that could and would adjust straight axles. I have an appointment next week, (takes about an hour). As a side note. Superior Spring moved from Hartford to Hamden quite some time ago. Superior still does a fair amount of hot rods and classic cars. Thanks for the help! Sounds like this type of work is becoming a lost art. Regards Sent from my iPad using Tapatalk |
07-05-2018, 02:54 PM | #13 |
That and radiator shops........................
Paul in CT |
07-05-2018, 02:59 PM | #14 |
07-06-2018, 05:31 AM | #15 |
I know someone who spent 500 getting a v8 radiator rodded out. Someone told me about an old school alignment shop in Taunton MA that can do that work,
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
07-06-2018, 08:31 AM | #16 |
Is your dropped axle an original Ford axle or an aftermarket axle? Most of the aftermarket axles are cast and not forged. I believe it makes a difference if they are going to cold bend it. Don't think you can cold bend a cast axle.
07-06-2018, 02:31 PM | #17 | |
The axle is an original that I had dropped. Thanks for the note. Sent from my iPad using Tapatalk |
07-06-2018, 03:48 PM | #18 |
YIKES! I surely didn't know that you could heat a CAST axle, and be able to bend it. Could you elaborate, please? DD
07-06-2018, 04:07 PM | #19 |
07-06-2018, 04:42 PM | #20 |
A dropped axle ,I certainly wouldn't try and bend it unless I new exactly what material its made of .Ted
