06-28-2018, 06:22 PM | #1 |
1935 Ford points
does anyone know where i can buy the adjusting screws to gap the points without buying the complete set?
i have 2 sets of points without the adjusting screws. |
06-28-2018, 10:54 PM | #2 |
Re: 1935 Ford points
Just about any good parts or hardware store should have them. Take your distributor plate along to make sure they fit. you may have to cut them off. This can be easily done with a pair of wire strippers.
06-28-2018, 10:55 PM | #3 |
I use allen cap screws. got tired of dropping the screws with a slot.
06-29-2018, 05:53 AM | #4 |
the screws i mean are the ones that contact the points, not the lock screws.
they used to be available separately without buying the full set. |
06-29-2018, 06:31 AM | #5 |
Southside Obsolete in MN might have them.
06-29-2018, 07:06 AM | #6 |
I probably have dozens of these I've removed from used '33-'36 distributors I've picked up at swap meets over the years. If you can't find them, I'll mail you a set.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-29-2018 at 07:13 AM. |
06-30-2018, 08:08 AM | #7 |
i'm trying o rebuild a spare distributor that's missing these screws.
let me know how much and i can paypal you to mail them. thanks |
07-02-2018, 06:28 AM | #8 |
t35, I sent you a PM on this several days ago. I need your name and address to send these parts to you.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 07-02-2018 at 10:54 AM. |
07-02-2018, 07:59 AM | #9 |
Just another thought , only the drivers side will show wear ! Its the break side . So i guess you could rotate the contacts every so many miles to get more mileage ?????? The Jack Benny effect i suppose ??????
07-03-2018, 07:59 AM | #10 |
John
I paypal'd you with n & a. let me know if you get it. thanks Tom |
07-03-2018, 11:06 AM | #11 |
Tom, nothing came through to me on PayPal. Check the email address. If you didn't use a dot/period between my first and last name, that message probably went to someone else with the same name. You would need to cancel that and use correct email address.
In the meantime, send me a pm using Fordbarns system with your mailing address.
07-03-2018, 11:51 AM | #12 |
Maybe
Works good Lasts long time |
07-05-2018, 10:39 AM | #13 |
Tom, received your mailing address, will get some of these in the mail to you with a little tip on how I resurface the contact end on these.
07-05-2018, 10:45 AM | #14 |
@cmbrucew.... Nice thought with the pic you posted I guess ???? , but no BS here.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 07-05-2018 at 11:08 AM. |
07-05-2018, 10:48 AM | #15 |
I guess I don't understand what's going on here, but I'm not getting a good feeling.
07-05-2018, 06:28 PM | #16 |
Thanks John..................
07-13-2018, 09:06 AM | #17 |
t35, just wanted to let you know that those points I promised to send should arrive at your place this Saturday, 7/14. I've resurfaced the contact tips on these for you, so they should be ready to install. Also sent you a PM on this. Good luck with your rebuild!
John
07-13-2018, 04:52 PM | #18 |
John
I received screws today. WOW. They're like new. thanks for your trouble. Much appreciated. Tom |
