Old 07-11-2023, 08:45 AM   #1
Automotive Stud
Automotive Stud's Avatar
Default Convert F1 transmission to torque tube
I figured this would be a common talk, but when I searched I found a lot of info on going to open drive and not the other way around. I have a few F-1 top loader open drive transmissions. What's involved besides the rear mount to convert the transmission to basically '39 spec torque tube?
Automotive Stud is offline   Reply With Quote
Old 07-11-2023, 09:37 AM   #2
cas3
Default Re: Convert F1 transmission to torque tube
you need the main shaft thats proper for the gear set you wish to use
Old 07-11-2023, 09:38 AM   #3
Zeke3
Zeke3's Avatar
You will also need to change the main shaft to something like a 81A-7061 that is compatible with the rest of your gears and the u-joint and attaching hardware for the u-joint. I use the tables of information in Mac Van Pelt’s transmission book to identify the individual components and compatibilities.
Zeke3 is offline   Reply With Quote
