05-24-2017, 06:43 PM | #1 |
1928 gas cap
I have a 1928 closed cab pick up. Everything I read tells me I should have a threaded gas cap but I have a gas cap that has tabs and it seals on a quarter-turn. All the catalogs show the 28 29 gas cap is threaded and the 30 31 with tabs. Is it possible to have a tabbed 28 gas tank? Thanks
05-24-2017, 07:15 PM | #2 |
Re: 1928 gas cap
The 28/29 CCPU style cab went to July 1930. 1930 gas tanks had the quarter turn gas caps. I could be wrong, but I suspect someone installed an early 1930 gas tank on your pickup.
Rusty Nelson |
05-24-2017, 07:22 PM | #3 |
Re: 1928 gas cap
Does it have a 7 tooth or 2 tooth steering gear with 30-31 type steering wheel.
Bob |
05-24-2017, 07:22 PM | #4 |
Re: 1928 gas cap
Rusty, you just beat me to it. JS says the quarter turn cap was introduced in April, 1930 and continued through June, 1930.
05-24-2017, 09:57 PM | #5 |
Re: 1928 gas cap
Well I think I have a 1928, How can I tell the difference between a 7 tooth and a two tooth the steering column is out but not disassembled? I do not believe the gas tank has been changed as I am the one who removed it and it seems like it was the original install, paint matched and original welting was in place. I do have 29 headlights though. What are some other ways I can tell a 28 from a 29? As you can tell I'm new to all of this, any help is greatly appreciated. Where is the engine s/n stamped on the frame? I assume that will help.
05-24-2017, 10:14 PM | #6 |
Re: 1928 gas cap
Here is another thread that may help. Picture #2 in the first post is where it should be... https://www.fordbarn.com/forum/showthread.php?t=221192
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-24-2017, 10:14 PM | #7 |
Re: 1928 gas cap
The 7 tooth steering has a one piece welded box and column, while the later 2 tooth steering has a clamp to hold the column to the main steering box.
05-24-2017, 10:19 PM | #8 |
Re: 1928 gas cap
There are pictures here
http://www.snydersantiqueauto.com/2-tooth-steering-box http://www.snydersantiqueauto.com/7-tooth-steering-box
05-24-2017, 10:19 PM | #9 |
Re: 1928 gas cap
Check this picture for frame number location.
Bob |
05-24-2017, 10:25 PM | #10 |
Re: 1928 gas cap
AA trucks used the tall cab like yours until mid 1930. The fuel tanks in the early 1930 AA trucks were the same shape as all 1928-1929 pickups, cars etc- only they had the non threaded 1/4 turn 1930 style cap.
05-24-2017, 10:26 PM | #11 |
Re: 1928 gas cap
When you find it enter it here...for the manufacture date of the engine.
http://www.modelahouse.com/cgi-bin/enumbers/numdate
05-25-2017, 05:50 AM | #12 |
Re: 1928 gas cap
Looks like I have a two tooth box which points to a 29 instead of a 28, right. Looking for engine number today. Thanks to all.
05-25-2017, 07:05 AM | #13 |
Re: 1928 gas cap
My 8-30-29 has the screw on gas cap.
05-25-2017, 08:07 AM | #14 | |
Re: 1928 gas cap
Similar to this
05-25-2017, 09:39 AM | #15 |
Re: 1928 gas cap
X2 Have you considered that the entire cab on your truck may be a transplant? Later cab on earlier chassis?
05-25-2017, 11:04 AM | #16 |
Re: 1928 gas cap
1928closed, welcome to the Barn. Where do you live? As you have have been informed; it is possible to have a 28/29 styled truck with the 30/31 1/4 turn gas cap. There are more out there then you realize. My Father-in-law has a AA with the later gas cap as well. Again welcome to the Barn, and post often. Jeff
Let's let pylons, be pylons! |
05-25-2017, 04:45 PM | #17 |
Re: 1928 gas cap
easy enough...the 2 tooth is a 2 piece column, the 7 tooth is 1 piece column.
Add your location to your reply info. it can help in finding a local guy to help you. |
05-25-2017, 10:28 PM | #18 |
Re: 1928 gas cap
Thanks, great information. Lafayette La
05-26-2017, 04:33 AM | #19 |
Re: 1928 gas cap
What does it mean when the serial number pad on the engine is blank?
05-26-2017, 04:38 AM | #20 |
Re: 1928 gas cap
