Old 06-22-2018, 06:32 PM   #1
cfrye002
Default 1935 Ford Rear Shock Test
Got the rear shock absorbers off the car, can turn them by hand easily with no resistance. Added 30wt jack fluid with the same result...need to be rebuilt?
Sent from my iPad using Tapatalk
cfrye002 is offline   Reply With Quote
Old 06-22-2018, 08:52 PM   #2
koates
Default Re: 1935 Ford Rear Shock Test
Yes, they need to be rebuilt. They would require some serious resistance in both directions to be classed as good. Even a length of pipe on the arm and push/pull like hell, that's the effort required to rotate them. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-23-2018, 01:24 AM   #3
Jembow
Jembow's Avatar
Same problem here. No one rebuilds them in the UK and they're heavy things to ship transatlantic. The Model A trick is to use MGB rears but on the V8 they foul the tyres. Rides a bit bouncy without them, I may have to fit tube shocks.
Jembow is offline   Reply With Quote
Old 06-23-2018, 06:23 PM   #4
J Franklin
J Franklin's Avatar
Don't you have machine shops in your areas. Or maybe a backyard shop somewhere that could fix the shocks, they are fairly simple mechanisms. Shafts can be hard chrome back to specs. O-rings and seals are available. Why not pay your machinist rather than postage?
Old 06-23-2018, 06:30 PM   #5
terry
C&G Ford Parts offers tube shock kits for front and back. Terry
terry is offline   Reply With Quote
Old 06-23-2018, 09:36 PM   #6
JSeery
JSeery's Avatar
Here is some past info on the subject:
https://www.fordbarn.com/forum/showt...ghlight=shocks
Old 06-23-2018, 10:04 PM   #7
fordor41
fordor41's Avatar
did you try to adjust them?
fordor41 is offline   Reply With Quote
Old 06-24-2018, 04:00 AM   #8
Karl
Karl's Avatar
I have a set of rears that are just clearing customs
They where done By Andrew Falandes
$200 each including cores -Shipping to New Zealand was only $120
He did my fronts as well -same deal -and I am very impressed with his work
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 06-24-2018, 09:18 AM   #9
rotorwrench
rotorwrench's Avatar
Andy learned the trade from one of the Barn's old contributors Bill Wzorek. The cores can be rebuild as long as there is a decent housing and wing shaft. There is some good information on here about Houdaille shocks if you do a search.
Old 06-24-2018, 12:29 PM   #10
terry
Karl, if you change flatbed to flathead that song becomes so much more interesting. Terry
Old 06-25-2018, 03:33 AM   #11
Karl
Karl's Avatar
Yep when I play and sing it (both very badly) I always change it to Flathead. But still a great line by a great band - Karl
Old 06-25-2018, 10:33 AM   #12
blucar
blucar's Avatar
If you change the rear shocks to tube type, mount them like the '47-48 Ford/Merc's, on an angle rather than vertically.
I have attached a pix of the tube shocks on the rear of my '36.
Bill.... 36 5 win cpe
Old 06-25-2018, 11:12 AM   #13
DavidG
DavidG's Avatar
Judging from the photo, you did not change to tube shocks, you added them to the existing shocks. Two shocks per wheel?
Old 06-26-2018, 10:22 AM   #14
blucar
blucar's Avatar
During my misspent youth, (1950's) I street raced my Ford on a regular basis. I wanted the car to be as stable as possible, therefore, I had double shocks on the rear, and a sway/panhard bar. Of course the addition of an anti roll bar on the rear would have negated the need to retain the original lever shocks. The front axle is modified also.
Old 06-27-2018, 11:37 AM   #15
Jembow
Jembow's Avatar
I've been giving this serious thought.
Option 1 is get Andrew Falandes to do me a set. With shipping, import duty etc we're probably looking at $1500.
Option 2 is to make a set of brackets to mount tube shocks, probably cost less than $200. But as this is a nice original car, that is only a temporary fix, long term I want correct shocks on it.
Option 3 is J Franklin's suggestion of fixing them myself. I have read the original shop manuals, which mention a lot of specialist tools, but we all know you can often improvise this stuff. I have Les Pearson's Model A book, which goes into detail on Houdaille shock restoration. Some of it sounds complicated, and when he talks about how get a very old unit apart, slightly scary! It would be nice to do it myself but that's going to consume time and I have so many projects on the go, it isn't going to happen in a hurry. Looks like I've talked myself into Option 1.
Blucar, how does the other end of your panhard rod mount?
Old 06-27-2018, 01:26 PM   #16
rotorwrench
I always got a kick out of folks putting them in a charcoal grill. If a person doesn't have a O/A torch then it makes sense. Very long cheater pipes are also used as well as very strong supports to bolt them to for disassembly.
Old 06-27-2018, 04:29 PM   #17
Jembow
Jembow's Avatar
Les Pearson says forget making strong supports, bolt them back on the car or a spare chassis
