Old 08-11-2020, 01:36 AM   #1
Jembow
Jembow's Avatar
Default Hood hinges - tube or rod?
My local vendor stocks a set of stainless tubes for the hood hinges. For the same price I could buy solid stainless rod. Which is better?
Jembow is offline   Reply With Quote
Old 08-11-2020, 05:00 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Hood hinges - tube or rod?
An old trick back in the day was to stick a brazing rod in there. If would go with something solid for sure.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-11-2020, 06:27 AM   #3
Jacksonlll
Jacksonlll's Avatar
I use brazing rods.
Old 08-11-2020, 06:51 AM   #4
kenparker
kenparker's Avatar
stainless rod from the local hardware store.
kenparker is offline   Reply With Quote
Old 08-11-2020, 07:16 AM   #5
dbaldwi3
dbaldwi3's Avatar
But what was factory? I’ve seen both not sure what Henry used...
dbaldwi3 is offline   Reply With Quote
Old 08-11-2020, 08:29 AM   #6
Big hammer
My late 31 Tudor has steel tubes, I've heard that wooden dowel could be used!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 08-11-2020, 08:51 AM   #7
jw hash
jw hash's Avatar
on the originals hood rods. the top way a tube and the sides were rods. I use stainless rod.
jw hash is offline   Reply With Quote
Old 08-11-2020, 08:57 AM   #8
Mike Peters
Mike Peters's Avatar
Here are some original hood rods. The top rod behind the radiator cap is a seamed 3/8" OD steel tube. The side rods are a solid 1/4" steel. The upper rod is difficult to remove without damaging. All these you see are beyond repair. Bent into a corkscrew or bent/crimped over at the ends. Whether you go with a solid or tubular upper rod, if something heavy comes down on your hood, it won't matter which you use.
A straight piece of 5/16" ID (3/8"OD) brake line is a pretty close fit for a top rod. But in the long run, a stainless rod won't ever rust.
Mike Peters is offline   Reply With Quote
Old 08-11-2020, 08:59 AM   #9
Jembow
Jembow's Avatar
Think I'll go for rods, thanks for the input. Got wood dowel holding it together right now!
Old 08-11-2020, 09:33 AM   #10
Ruth
Originally Posted by Jacksonlll View Post
I use brazing rods.
Where do you find a brazing rod that thick? ⅜" for the center rod I believe? Thanks.
Ruth
Old 08-11-2020, 10:52 AM   #11
Jacksonlll
Jacksonlll's Avatar
I got them at a welding supply shop. That is very big to braze with.
Old 08-11-2020, 11:01 AM   #12
Purdy Swoft
Purdy Swoft's Avatar
I have always used stainless rods from the model A parts vendor .
Old 08-11-2020, 11:12 AM   #13
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
There are 3 places in a Model-A where this rolled tubing is used. Wanna take a guess where the other two places are>>
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-11-2020, 11:16 AM   #14
Ruth
Tie rod?
Ruth
Old 08-11-2020, 11:37 AM   #15
Gary Karr
Gary Karr's Avatar
Radiator support rods and horn rods
Gary Karr is offline   Reply With Quote
Old 08-11-2020, 11:47 AM   #16
Truckerjim
Tubes are stronger Learned this working on hydraulic rods and tubes ,more surface area to bend makes it stronger with less weight.
Truckerjim is offline   Reply With Quote
Old 08-11-2020, 01:03 PM   #17
Mike Peters
Seamed gas lines and 28-29 radiator tubes. That makes about 5 seamed tubing applications.
Old 08-11-2020, 07:30 PM   #18
dbaldwi3
dbaldwi3's Avatar
Not sure if this counts As one but the rear radius rods Are seamed
Old 08-11-2020, 08:04 PM   #19
Chris Haynes
Chris Haynes's Avatar
Lubricate your old rods in the hood. Then punch them out a bit. Connect a drill motor to them to spin them as you pull them out. Makes the process a lot easier.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-11-2020, 08:25 PM   #20
McMimmcs
McMimmcs's Avatar
Thirty or 40 years ago my dearly departed uncle wisened me to that procedure. I must have passed it on to 100 people by now.
