01-23-2018, 12:45 AM | #21 |
Re: Valve laping with power drill?
Just went to a site Ronnie suggested, do I understand that the intake and exhaust valves are not interchangeable because they're cut differently, if that's the case no wonder they're leaking?
01-23-2018, 12:49 AM | #22 |
i agree with Kurt, you should know which ones to look at, and also many shops dont have the real flathead ford pilot that is long enough that it centers in the lifter bore, and also the guide bore so its all straight. i know of two "engine rebuilders" that have a home made tapered thing that only fits the in guide. they tell me it works, done tons of flatheads, but i dont buy it. your laping will just show what the problem is, but it wont fix it if things are not straight and cut right to start with.
01-23-2018, 12:52 AM | #23 |
Seat angle and size are the same it´s the material they are made of that is different.
01-23-2018, 12:53 AM | #24 |
intake and exhaust are generally only different materials due to high heat on the exhaust valve. race motors could have all kinds of other things goin on, not my area to discuss.
01-23-2018, 12:54 AM | #25 |
murry beat me!
01-23-2018, 01:00 AM | #26 | |
More of the factory buillt pilots are short then long...the most common long ones are B&D...kwik way, Sioux are short. |
01-23-2018, 10:54 AM | #27 |
in my thinking, using a pilot that is only in the upper bore, you could be crooked and not in a true line with the lifter, which would then cause premature wear on one side of the guide. but...i am no expert engine guy. when i bought my old black and decker super service valve machine a few years back, it came with 3 long pilots for fords. i sold the two extra on ebay and nearly got the machine paid for!
01-23-2018, 11:21 AM | #28 | |
01-23-2018, 11:34 AM | #29 |
My valves are all S.S. so they're interchangeable, when I saw SPEEDWAY cuts the their intake and exhaust differently, I thought maybe that was the problem.
Will post pictures of seats and valves in the next couple of days. Will flush cooling system and get rid of the NO-ROSION, try and sacrificial anode. would dis-tilled water be a good idea to help reduce erosion? Thanks for the help guys. |
01-23-2018, 11:48 AM | #30 |
Not on it's own. Just use it with some good quality anti-freeze/summer coolant, like in your modern car.
Mart. |
01-23-2018, 02:07 PM | #31 | |
I am also curious why folks prefer a marker to check their valve margin, seems like the ink would be too thin, and dry too quickly, to transfer and be a useful indicator. |
01-23-2018, 02:23 PM | #32 |
You need composite gaskets with Aluminium .observe the use life of anty freeze it becomes corrosive after a while .I prefer soluble oil .Ted
01-23-2018, 04:25 PM | #33 |
I'm lead to believe that the proper modern red antifreeze can attack the lead soulder in our old radiators and heater cores. So I use older type blue stuff.
Martin. |
01-31-2018, 12:20 AM | #34 |
So heres a few pictures of my leaky valves, (90 over 75) on leak down test on my worst cylinder # 4.
I had very recently honed the cylinders and installed new rings and am surprised to see this ridge line at the top of all the cylinders, any thoughts on this? Anything about the valves or seats that jump out at you? |
01-31-2018, 06:45 AM | #35 |
Are the valve/seat angles mismatched? The contact seems to be a single thin line(???).
I'd grind/lap em in and reset the gaps and start running it again. The gaskets look reusable to me too. (I'm a cheapskate). Mart. |
01-31-2018, 09:39 AM | #36 |
There is no assurance the tappet bore and the valve seat are concentric. I stopped using my long pilot when I noticed the fresh cut seats were running well off center from where the valves had been operating. I think a good, snug fit into the valve guide bore is the proper place for piloting.
Lapping of the valve/seat must be done with a minimum of compound spread evenly. It must not be allowed to vary in thickness or allowed to "stack up". Using the back and forth, lifting and shifting locations method is my recommendation. Are the valve spring pressures and the tappet clearances correct? |
01-31-2018, 12:13 PM | #37 |
JWL, its interesting that you quit using the long pilot. i too have seen valves that seemed off center from the pilot, but always assumed it was because the guy before me used a short pilot. you dont think the factory had that all straight when they did it?
01-31-2018, 12:25 PM | #38 |
At our shop we replace all valve seats eliminating lapping in rebuilds. If your engine needs valve lapping, it is probably due to seat erosion or previous poor installation.
01-31-2018, 01:22 PM | #39 |
My tool pilots in the both the lifter bore and the guide bore.
01-31-2018, 02:02 PM | #40 |
Thanks for responding everyone, I value your opinions.
As far as seat pressure, the springs are a stock type and I have gone through the valves twice to confirm clearances. In the picture I posted,. does anyone have an opinion as to what the ridge at the top of the cylinder is and should I be concerned? Will proceed by hand lapping the valves, some have mentioned success in using a black marker pen rather than the blue stuff, what should I look for when using the black marker. Mart thinks the head gaskets are re-useable, I was hoping that would be the case. |
