Old 02-09-2015, 05:18 PM   #21
Ian NZ
Ian NZ's Avatar
Default Re: silicone brake fluid proof brake light switch
Originally Posted by JSeery View Post
Bad cups? Have you considered a residual valve to maintain some pressure on the wheel cylinders?
Do you think you really need to run a 2-lb residual valve in the Ford V8 hydraulic brake systems, i thought that was already incorporated in the V8 master cylinder.
Ian NZ is offline   Reply With Quote
Old 02-09-2015, 05:34 PM   #22
JSeery
JSeery's Avatar
Depends on the master cylinder, some have them and some do not. Not having them can be a source of wheel cylinder leakage.
Old 02-09-2015, 09:03 PM   #23
FlatheadTed
FlatheadTed's Avatar
Thanks for the tip ,The duel M cylinder is a modern one so I would think maybe there is a valve in the out let only , ? disk and drum M/C
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-09-2015, 09:46 PM   #24
JSeery
JSeery's Avatar
Maybe, maybe not, depends on how the system was set up. As an example might have had a combination valve that served that function.
Old 04-24-2019, 08:32 AM   #25
Automotive Stud
Automotive Stud's Avatar
Originally Posted by V8COOPMAN View Post
Suggestion below! DD
Ron Francis sells a silicone compatible switch that has been mentioned here several times.
http://www.ronfrancis.com/prodinfo.asp?number=SW%2D32
Item Number: SW-32Unit Price: $28.95In Stock
I know this is an old thread but I'm running dot 5 and I'm on my second one of these switches in two years. Does anyone really offer a true dot 5 compatible switch?
Automotive Stud is offline   Reply With Quote
Old 04-24-2019, 08:39 AM   #26
JSeery
JSeery's Avatar
I thought the Harley switches were, but not positive.
Update: Genuine Harley Davidson, part # 72023-51D
OK, second update! This was already covered in detail earlier in the thread!!!!
Old 04-24-2019, 09:06 AM   #27
38bill
38bill's Avatar
I was running the Harley switch and it failed too. I ended up switching back to DOT3 when I did a total rebuild of the brake system.
38bill is offline   Reply With Quote
Old 06-12-2019, 09:14 PM   #28
nelsb01
nelsb01's Avatar
So, does anyone have an answer? I was over reading the Harley boys forum and they are not buying HD switches because they are not made by HD and fail. They suggested Accel 181101.
Anyone using that one? I am gettting tired of the 9 month and replace $9.99 ones that I now buy 10 at a time.
nelsb01 is offline   Reply With Quote
Old 06-13-2019, 02:24 AM   #29
tiger.1000
I agree with BINX. Don't use silicone fluid. Stay with DOT 3 and perhaps every two years or so bleed the system and renew the fluid. £5 will buy you a brake fluid tester which will determine if there's any water in the system and it's water that's the killer.
tiger.1000 is offline   Reply With Quote
Old 06-13-2019, 04:48 AM   #30
richard crow
i use the chevy lever switch the reason is they can be adjusted to be more senative the hydl switch requires pressure. the lever switch puts the lights on sooner giving the car behined you more time to know your stopping .plus i use dot five if your car sits it,s the best way to go
richard crow is offline   Reply With Quote
Old 06-13-2019, 09:19 AM   #31
deuce lover
deuce lover's Avatar
I'm with Richard.To me the hydraulic ones are a waste of time.The lever switch is the only way to go.Its foolproof. Just touch the pedal slightly and the brake lights come on.Used it on last 5 cars I built.Speedway has them pretty cheap.
Here it is $6.99 at Speedway
https://www.speedwaymotors.com/Speed...itch,1972.html
Old 06-13-2019, 09:48 AM   #32
TJ
TJ's Avatar
I've used the lever switches for years. Never had one fail so far. It's a simple solution when using dot 5 fluid. Depending on where you buy the switch they cost between $10-15 and it's a one time purchase.
Old 06-13-2019, 10:03 AM   #33
Tony, NY
Yeah. Give up on the hydraulic switch and go to one off of the pedal, as said.
https://www.amazon.com/Allstar-Perfo.../dp/B003C01FFY
Tony, NY is offline   Reply With Quote
Old 06-14-2019, 04:05 PM   #34
Ronnieroadster
Ronnieroadster's Avatar
Years ago when i had the same failure with silicone fluid and the original style brake light switch i spent time trying to figure out why they fail. I found the seal in the brake light switch was the problem its not compatible with silicone. Once the seal fails the two contacts inside the switch are now flooded with the silicone fluid. The fluid now is causing a high resistance to make the contacts work correctly if i pressed really hard on the pedal the brake lights would work. Any heavy duty brake light switch would still have the same problem there called heavy duty to handle more load not a change in brake fluid type. My solution is exactly as others have written a mechanical brake light switch problem solved.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 06-14-2019, 04:42 PM   #35
d.conrad
d.conrad's Avatar
HD switch is smaller and cheaper than Ron's ( about half the price).. Works great and I'm told HD uses silicone brake fluid.
d.conrad is offline   Reply With Quote
Old 06-15-2019, 07:44 PM   #36
alanwoodieman
I have a HD switch on my wagon for almost 30 years! bought a ron francis switch for my 41 truck and it lasted about 10 years. silicon molecules are so small they sneak past the disc in the switch effectively neutralizing the switch
Old 06-16-2019, 09:18 PM   #37
Yoyodyne
Yoyodyne's Avatar
I don't think it's the silicone fluid making them fail. I started having those switches fail 40+ years ago before there was silicone fluid. old ones lasted for years, newer ones failed in a year or so with DOT3. American made, etc.
Yoyodyne is offline   Reply With Quote
Old 07-11-2022, 10:53 AM   #38
vanhammer
Originally Posted by alanwoodieman View Post
I have had two of Ron Francis's swithes fail, so far none of the HD switches have failed? when they failed the silicon got thru the seperation and hydro locked making the switch not work-how do I know this, I drilled on of the switches and fluid ran out, after letting the fluid out the switch worked
I know this post is old, but I got one of the Ron Francis switches in 2016. Did not install it for a year or two and I have not even put 100 miles on the car. I dont have any brake lights now unless I press very hard on the pedal. I am running less than 3 amps through the switch. Warranty is out of course, but they would not even knock off a small percentage to get another one. I think I will go with the HD one.
vanhammer is offline   Reply With Quote
Old 07-11-2022, 11:12 AM   #39
Automotive Stud
Yeah I've switched to the lever switches on all of my cars after having two Ron Francis switches fail. Never tried the Harley but I was tired of messing with it. I only had one lever style switch eventually wear out and it was 20 years old.
