Old 09-09-2022, 03:46 PM   #1
fritz29
Default distributor cam stuck
The cam is stuck on one of my distributor shafts.
Anyone have any ideas on how to free it?
fritz29 is offline   Reply With Quote
Old 09-09-2022, 04:17 PM   #2
Marshall V. Daut
Default Re: distributor cam stuck
Heat the distributor cam with an acetylene torch, but not red hot. If the distributor is out of the engine, immediately dunk the hot cam into a bucket of water. Repeat heating and quenching cycles until the cam can be pried off the upper distributor shaft.
If the distributor is still in the engine, allow the hot cam to cool and repeat heating-cooling cycles. It will take longer than quenching it in a bucket of water, but eventually heat will do the trick.
Marshall
Old 09-09-2022, 08:17 PM   #3
Gene F
Gene F's Avatar
Hmmm. It you pop it out, can you straddle it in a vise, take the cam screw out, and get a long narrow drift punch to bottom out without chewing up the threads? Proably just a few light taps, and the shaft might drop out. A helper might be handy.
Gene F is offline   Reply With Quote
Old 09-10-2022, 10:28 AM   #4
GeneBob
If is is out of the car, I have had good luck with Evaporust. Put it in a coffee can with enough Evaporust to cover the cam and walk away for about 3 days. Then spray with penetrating oil and let that soak for several minutes to a day. You should be able to start moving it. If not, then go for the big guns mentioned earlier.
GeneBob is offline   Reply With Quote
Old 09-10-2022, 10:29 AM   #5
rotorwrench
rotorwrench's Avatar
Tight fitting steel parts like that don't take too many years to seize in place. I use a heat gun that will get a part up to the boiling temperature of water. This is usually less than 250 degrees F. Hit it with water and it will shock the part joint. As was previously mentioned, this may take a few times. Lock the bottom of the shaft in a soft jaw vice and use the cam turning tool to get it to move with liberal use of penetrating oil. It will move eventually and then it can be taken off the shaft.
