12-31-2012, 10:36 PM | #1 |
1937-40 Engine Splash Pans
I Have a '37 Ford with a 85 hp engine and was hoping that someone wiser than me could give me some help. I am attempting to install the driver's side engine splash pan on a full up car. I've disconnected the Drag Link from the Pitmann Arm and dropped the Tie Rod end from the spindle on that side. Iive tried to get the Pan on but it looks as though i will have to pull the Pitman Arm to accomplish this. I Have a Puller but was wondering if anyone out there might have a better way to offer up that pan to its m ounted position.
Thank you very much and HAPPY NEW YEAR!! Richard Contact me here or [email protected] |
12-31-2012, 11:33 PM | #2 |
Re: 1937-40 Engine Splash Pans
I think you are going to have to remove the pitman arm to get the pan on or off. Don't move the steering wheel and you should be able to just slip the pitman arm off and back on without having to do any adjustments.
12-31-2012, 11:37 PM | #3 |
To avoid removing the pitman arm. I cut the splash pan at its narrowest place right near the round hole with a hack saw and was able to gently bend it around to it would slip on. I then used a small piece of sheet metal and a sheet metal screw to "rejoin" the cut. It worked great for many years. Sure made things much easier. When i sold the pans, I just welded the cut back up good as new.
01-01-2013, 09:32 AM | #4 |
From my experience, most of these pans were cut through there life as 19FORDY had done. In fact, I have come upon more that were cut, then not cut.
It is easy to remove the pitman arm so as to avoid damaging the pan.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 01-01-2013 at 10:58 AM. |
01-01-2013, 10:13 AM | #5 |
I did the same as Fordy. I also made a small sectional piece and painted it black and reattached with four sheet metal screws. It looked great.
01-06-2013, 09:07 PM | #6 |
To remove or install a left (drivers side) engine pan, you need to raise the frame and let the front axle droop,(once the drag link is removed) so that you get wiggle room to get the engine pan off without taking the pitman arm off. I've done this many, many times from parts cars without cutting the engine pan, which is the lazy mans way. The only problem is with a restored car you may scratch the oil pan or frame paint. |
01-06-2013, 10:05 PM | #7 |
I can see why a lot of these pans are missing.
I have a pretty pure original '40 sedan with the pans and a couple others without. The pans make it damn hard to R&R the starter and it seems like some other jobs were harder too, but CRS prevents me from listing all of them! Unless it's a points car I'd hang 'em on a nail in the barn. |
11-18-2019, 05:28 PM | #8 |
1937 RHD Engine Splash Pans.
I am looking for a set of 1937 RHD engine splash pans for my 5W coup’e. I require one of each, for the left, right and centre pan positions. I presume the centre pan would be the same for both the RHD and LHD vehicles. Any leads or advice would be appreciated. The attached photograph shows a set of LHD splash pans. Thanks Roger Carter Airlie Beach, Queensland, Australia. |
11-19-2019, 06:25 AM | #9 |
Nospartsman...Glad to see you post again.
11-19-2019, 10:58 AM | #10 |
Look again.... that post was eight years ago. He's been permanently banned from the Barn.
11-20-2019, 06:15 AM | #11 |
I missed the date on the post. Wonder who posted it on the current thread. In any case, I miss his posts. He has a wealth of knowledge when it comes to Ford parts. I have bought parts from him and he has bought parts from me for quite a few years.
11-20-2019, 09:29 AM | #12 |
On my 39 I installed the pans with engine out. Did drop the drag link to fit the left one. Hard to find nice ones as many got tore off over the years.
