Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 04-21-2017, 04:39 PM   #1
Brian T
Brian T's Avatar
Default Coupling shaft
City: San Diego
State: Ca
I am still seeking a coupling shaft that was used on a 28-29 Double A truck, it is the shaft between the transmission and the main drive shaft, where a Hi-Low reduction box was used, but not factory fitted.
My intensions are to install a Mitchell transmission with 15% improved 1st- 2nd gears, and remove the Hi-Lo unit, I am hoping someone may have a coupling laying around that they wish to dispose of,---- in addition a u-joint with 6-10 splines that has the replaceable cross in any condition as long as the knuckles are not worn would be helpful.
Thank for looking.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 04-26-2017, 02:54 PM   #2
Brian T
Brian T's Avatar
Default Re: Coupling shaft
Back to the top.
Old 05-06-2017, 02:30 PM   #3
Brian T
Brian T's Avatar
Upwards
Old 05-12-2017, 04:01 PM   #4
Brian T
Brian T's Avatar
To the top again
Old 05-25-2017, 08:24 AM   #5
Brian T
Brian T's Avatar
Let's go back up.
