I seem to have 1/2 of the power cord: it comes from the right side of the radio and is about 10" long, ends in a cup suggesting there's a 2nd half wire with a male ending to fit snugly into the cup (twist in?). I'm advised the missing wire also includes a fuse then continues on to connect to either the resister on the firewall or goes to the ignition, not sure which. Can't seem to find the missing wire anywhere. I could make a wire w. a fuse, but can't make the male twist on piece to properly fit the end piece I have. I suppose I could just cut off the female end, and then connect its 2 (?) internal wires to the wire I could then make?
