12-07-2017, 06:35 PM | #1 |
What is this tool for ???
Poking around in one of my pop's toolboxes I found these two tools.
It appears that they were once one a double ended tool and pop cut it in two. Probably a clearance issue. One end is a hex socket the other a spanner. Maybe someone has one similar. Any ideas ??? |
12-07-2017, 06:39 PM | #2 |
Re: What is this tool for ???
Brake spring hold down tool
Sorry, after closer look not that. Maybe for adjusting solid lifter rocker arms. |
12-07-2017, 06:39 PM | #3 |
Itty, bitty nut driver and a special key to unlock a coin machine.
12-07-2017, 06:42 PM | #4 |
the left one looks like a nut driver the right looks like the tool too remove ignition switch on the 50s fords.thats my guess
12-07-2017, 06:44 PM | #5 |
Looks like a distributor tool. The slotted driver end fits the primary post on a 216 Chevy, if I remember. Looks too small to fit an ignition switch.
12-07-2017, 06:48 PM | #6 |
12-07-2017, 10:02 PM | #7 | ||
When I was doing tune up service on Chevy 6 distributors, I had a tool that looked like that. It may well work for carburetor service also.
Enjoy yer day. Tom Hate can't fix what it started. |
12-07-2017, 06:59 PM | #8 |
Don't know but it's a goodun !!
12-07-2017, 08:06 PM | #9 |
I think the one on the right is for the barrel nut used on the crab distributors.
12-07-2017, 08:13 PM | #10 |
Standard zerk and alamite pin zerk tools?
12-07-2017, 08:56 PM | #11 |
the one on the right may be used to remove some of the 49 to 53 bezels on the dash (light switch) i have one with the similar two small extensions to remove the locking ring on the switch retainer.
12-07-2017, 09:13 PM | #12 |
As stated above. Carburetor jet and component installation/removal tools.
12-08-2017, 12:16 AM | #13 |
I Think they are for carb. jets
12-08-2017, 07:15 AM | #14 |
It is a tool used on the older Delco distributors. It fit the stud & nut thru bolt on the low voltage terminal on the side of dist.
Picture of an un-altered tool. Last edited by 42merc; 12-08-2017 at 07:39 AM. |
12-08-2017, 01:24 PM | #15 | |
I have one as posted by 42 merc. KR Wilson made a similar for use on the applications I have noted. Those were probably originally part of the larger tool that was cut in two to make the individual drivers. Larry |
12-09-2017, 06:15 AM | #16 | |
12-08-2017, 07:47 AM | #17 |
ahh, closure.
12-08-2017, 10:14 AM | #18 |
that splanes that one lucy
12-08-2017, 10:26 AM | #19 |
Muffler bearing remover. Pete/Ct.
12-08-2017, 11:49 AM | #20 |
Thanks 42'merc !
I am going to mount it on the wall with about 30 other obsolete and unidentified old tools I have. When they have my auction they will probably go for a pittance as nobody will know what they are for. |
