06-21-2010, 08:28 PM | #1 |
loosing water.
The huckster I'm working on has a new radiator, and a new leakless water pump. I took it out for a few miles last night and topped the radiator before I left. checked it today and water is at the top of the tubes. The overflow tube is up into the center of the radiator. The baffle is down some, and I can see the tubes in the center of the radiator, directly under the filler.
I'm hopeful the problem is not a cracked block, or even a loose head gasket. I replaced the plugs and all were sooted up. Oil was dark, but no evidence of water in the crank case. New oil looks good so far. I'm wondering if the impeller is kicking the water out the overflow. I'll look at that tomorrow. Is grinding down the impeller a solution to consider? Thanks for any thoughts. Bob |
06-21-2010, 09:39 PM | #2 |
Re: loosing water.
I'm suspicious of the baffle. I have seen some baffles that were built so that you could see the tubes in the center like yours. But they had a "wall" in front of the radiator input neck that blocked the water from getting into the overflow tube area. I have also had to remove stock from new water pumps to prevent water from being pushed out.
I noticed the harder I work the luckier I get! |
06-21-2010, 09:45 PM | #3 |
Re: loosing water.
Could it possibly have had an air bubble trapped ? Monte
06-21-2010, 11:49 PM | #4 |
Re: loosing water.
MAG: I don't think the replacement radiator is that great. Tomorrow I'm going to run the motor until it warms up in the carport and keep an eye down the radiator to see what happens. Its real possible the baffle is not doing the job. |
