Old 07-30-2020, 01:33 PM   #1
DannL
DannL's Avatar
Default Brass fuel shut-off valve binding.
Any thoughts why it has become very hard to turn on and off? This is a new brass valve (original style), installed in the spring. I've been using Marvel Mystery Oil in the gas for a while now. Thanks in advance.
DannL is offline   Reply With Quote
Old 07-30-2020, 01:54 PM   #2
Brentwood Bob
Default Re: Brass fuel shut-off valve binding.
Is the tank clean? Or is it shedding rust particles?
You might have to cleanup the tank.
Brentwood Bob is offline   Reply With Quote
Old 07-30-2020, 03:21 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
I would try slightly backing off on the packing nut . It will probably be necessary to first remove the handle for access .
Old 07-30-2020, 08:17 PM   #4
Sunnybrook Farm
Sunnybrook Farm's Avatar
I have rebuilt them and the least little rusty gas will kind of start clogging it up. It is just a brass cone that fits perfectly in the brass housing. there is a hole that lines up to allow gas to flow. It is a tight fit so that a little grit or rusty goo will make it hard to rotate. Sometimes sealer from years ago will make your life miserable as it works in there as well as the carburetor. I lapp the two surfaces with toothpaste as it doesn't cut as quickly as grinding compound. Graphite packing rope form the hardware has worked for me so far but I think the vendor sell something else. Some modern reproductions are poorly made and don't mate up well but you would know as it would leak.
Sunnybrook Farm is offline   Reply With Quote
