Old 06-13-2021, 02:39 PM   #1
Fred F. Griffin
Default Knock Knock
Have a knock that sounds like it is coming from the Starter or possibly the flywheel. Any ideas! Thanks! Thanks
Fred F. Griffin is offline   Reply With Quote
Old 06-13-2021, 02:52 PM   #2
Gene F
Gene F's Avatar
Default Re: Knock Knock
When did this start? You have owned the car for years? What have you investigated so far? When you drive the car down the driveway, does load, or coast affect it? Only knock when idling?
Old 06-13-2021, 03:52 PM   #3
Fred F. Griffin
Started it up to pull back in the garage and heard the knock. Pulled it in and proceeded to use a 1” wood dowel rod to listen and find the noise (old trick my dad taught me). Seems like the majority of the noise was coming from th starter area.
Old 06-13-2021, 03:53 PM   #4
Fred F. Griffin
I put my hand on the starte and can feel it. Possible flywheel problem?
Old 06-13-2021, 03:55 PM   #5
Fred F. Griffin
Starter problem? Just don’t know. Hate the thought of removing the motor.��
Old 06-13-2021, 04:04 PM   #6
700rpm
700rpm's Avatar
Pull the starter & check for damaged spring or spring bolt, condition of the bendix drive, and trueness of the shaft. Run a bench test on it by attaching jumper cables and watch for wobble. While you have it off, turn the engine by hand and observe the flywheel gear to ascertain any chipped, broken, or missing teeth. If all this seems good, I don’t know what else I’d check.
Put your location in your avatar. There may be someone close to you can help.
Ray Horton, Portland, OR
Old 06-13-2021, 04:28 PM   #7
Patrick L.
Patrick L.'s Avatar
Kinda sorta sounds like the stater drive is hitting the ring gear. Just remove the starter and take a look. While its out check that the ring gear hasn't walked and is in place.
Old 06-13-2021, 04:37 PM   #8
Fred F. Griffin
It is an AR flywheel. WHat do you mean by “walked”?
Old 06-13-2021, 04:41 PM   #9
Tacoma Bob
Tacoma Bob's Avatar
Ring gear is loose and ready to come off.
Tacoma Bob is offline   Reply With Quote
Old 06-13-2021, 05:30 PM   #10
Patrick L.
Patrick L.'s Avatar
The ring gear can move over the years and might not be against the flange as it should. Once the starter is out just take a look as you turn the engine over to get a good look at the full diameter of the flywheel. If it's 'walked' you'll see a gap. If thats happened the wheel can be driven/tapped back into place and staked. The engine can be turn over using a screwdriver/prybar thru the starter hole against the ring gear.
Old 06-13-2021, 05:53 PM   #11
1crosscut
1crosscut's Avatar
Remove the starter and start it using the hand crank. If the noise is gone you've narrowed down the possibilities.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-13-2021, 06:30 PM   #12
Greg Jones
Greg Jones's Avatar
Pulling a Model A starter is not so bad, pretty easy actually in the big scheme of things. Another thing to check is starter mounting bolts being too long, but I presume if that was the case you would have heard it long before now.
Greg Jones is offline   Reply With Quote
Old 06-14-2021, 11:23 AM   #13
katy
katy's Avatar
Take one of the cables off the battery before removing the starter.
When removing the starter, remove one bolt, replace it with a headless bolt. Then remove the other 2 bolts. When reinstalling the starter the headless bolt helps to hold the starter in place while you re-install the other 2 bolts.
Old 06-14-2021, 03:39 PM   #14
Fred F. Griffin
What does “staked” mean? In one of the replies. Thanks!
Old 06-15-2021, 10:00 AM   #15
katy
katy's Avatar
Staking is using a sharp punch to displace metal to make something fit tighter. For example, if one had a nut that was a loose fit on a bolt or stud, taking a hammer and a sharp punch and punching a bunch of divots on one side of the nut, close to the threads.
Another example would be on a starter or generator, where the flat head bolts holding the field poles in place there is no lock washer. Sometimes the metal around the head of the bolt is staked (using a sharp punch, displacing some of the body metal) to "lock" the bolt in place.
Hope this makes sense.
Old 06-22-2021, 12:53 PM   #16
Fred F. Griffin
Took starter out and found that the flywheel ring gear was walking out. The starter pinion gear was worn and not meshing with the ring gear. It was hammering the gear off. Kept turning the flywheel with the crank and lightly taping it back tight. Then I will stake it to the flywheel next. Wish me luck and thanks for the ideas!
Old 06-22-2021, 03:36 PM   #17
CarlG
CarlG's Avatar
Who's there?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-22-2021, 03:54 PM   #18
Fred F. Griffin
Fixed the problem! Back in the game! Yes
Old 06-22-2021, 04:15 PM   #19
Patrick L.
Patrick L.'s Avatar
Good.
Old 06-22-2021, 05:46 PM   #20
700rpm
700rpm's Avatar
Thanks for the followup.
