Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 05-27-2010, 01:54 PM   #1
dontlifttoshift
Default Wanted Victoria Drip Rails Window Frames
City: Waukegan
State: IL
Like the Title says we need drip rails and garnish mouldings for a LeatherbackVictoria. Any leads would be appreciated.
Thanks
Donny
Last edited by dontlifttoshift; 05-28-2010 at 08:46 AM. Reason: Being more specific
dontlifttoshift is offline   Reply With Quote
Old 05-27-2010, 06:34 PM   #2
jw hash
jw hash's Avatar
Default Re: Wanted Victoria Drip Rails Window Frames
I take it you have a leather back victoria and need drip rails they are pretty hard to find I use tudor drip rails and make a plywood pattern of the bent in the rear heat the rail up and very carefully bend the drip rail around your pattern. on the garnish moldings which ones do you need I have some. John Hash 253 833 9364
jw hash is offline   Reply With Quote
Old 06-10-2010, 11:37 AM   #3
dontlifttoshift
Bump...still looking for stuff. Found some from John Hash.
Thanks
Old 06-11-2010, 08:31 AM   #4
kmohney
Donny,
I have a passenger side door window frame that is decent, and a driver side door window frame that is missing the top rail and has some rust holes in the front section. I also have a passenger side door garnish molding that is in fair condition. If you are interested I can send photos.
Kirk Mohney
Gardiner, Maine
207-582-8040
kmohney is offline   Reply With Quote
