Old 09-10-2015, 05:07 AM   #1
DANA BIZZELL
DANA BIZZELL's Avatar
Default oil drip
My 31 coupe has always dripped a little, just noticed last couple weeks no drips after oil change, filler cap has been pushed down to far is only thing i can think of any other opinions.
Thanks
Dana
DANA BIZZELL is offline   Reply With Quote
Old 09-10-2015, 06:51 AM   #2
Charlville
Charlville's Avatar
Default Re: oil drip
Bit of a stab in the dark but did you change the oil grade by any chance?
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 09-10-2015, 10:02 AM   #3
H. L. Chauvin
Hi Dana,
One concern may be:
Roughly, how many quarts of new oil were added after draining old oil?
H. L. Chauvin is offline   Reply With Quote
Old 09-10-2015, 10:09 AM   #4
Mitch//pa
i thought they were supposed to leak
Old 09-10-2015, 10:19 AM   #5
Willie Krash
Willie Krash's Avatar
If mine doesn't leak I check the oil.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 09-10-2015, 10:25 AM   #6
burner31
burner31's Avatar
Give it time, she's just messing with ya
Keith
Shawnee OK
'31 SW 160-B
Old 09-10-2015, 10:38 AM   #7
Big hammer
Ok yes they mark their spots:-) but YES the fill cap needs to breath or they can build up pressure and leak!
Old 09-10-2015, 01:08 PM   #8
DANA BIZZELL
Has been leaking four years, same weight and amount of oil that i have been using.
Thanks
Dana
Old 09-10-2015, 01:46 PM   #9
Tiny
Tiny's Avatar
It's out of oil!!!
Old Harleys, Aircooled VW's, and Old Fords only stop dripping when they have no oil in them.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 09-10-2015, 03:46 PM   #10
amodel25
amodel25's Avatar
Like an old man told me one time many years ago while he watched me pour a quart in my '51........."It's a Ford. If it ain't leaking or smoking, it's empty".
amodel25 is offline   Reply With Quote
Old 09-10-2015, 03:50 PM   #11
marc hildebrant
marc hildebrant's Avatar
My car went from a steady leaker to hardly any when I changed them amount I add after an oil change from 4 1\2 quarts to 4 quarts.
I keep the oil around halfway between the two lines.
Marc
marc hildebrant is offline   Reply With Quote
Old 09-10-2015, 04:32 PM   #12
mshmodela
mshmodela's Avatar
Hey I think most 84 year old's drip a little --even Model A's.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 09-10-2015, 04:35 PM   #13
CWPASADENA
CWPASADENA's Avatar
Marc
I agree.
This seemed to help the leak in my car. It will now weep a little occasionally a drop or two but hardly any real leak at all. I just watch to be sure the level does not drop below the "L" mark.
I am very pleased.
Chris W.
CWPASADENA is offline   Reply With Quote
