07-26-2017, 10:43 AM | #1 |
1935 right hand drive question.
Hi All,
I am busy repairing all the extra holes in the dashboard for my 35 phaeton. I came to realize that it has a start button on the right hand side of the dash. I did some checking and the 4dr touring sedan that I chopped up for parts also has a push button start switch on the dash. These start switches are the same as fitted to 39 and 40 models. I checked the old wiring loom on my sedan and in place of the floor operated start switch it has a floor operated headlight dip switch. The wiring from the dip switch goes directly to the normal bottom of the steering column switch and it all appears to be original. My question please, to other owners of 1935 right hand drive cars is, are your cars the same as mine. I'm wondering if the floor operated dip switch and dash mounted start button were a requirement for cars supplied to the British colonies. I welcome your answers, many thanks Viv Westbury. |
07-26-2017, 11:27 AM | #2 |
Re: 1935 right hand drive question.
Any RHD 35 Ford I've seen has a foot operated starter button protruding between the brake and clutch pedals. No push button on dash or firewall mounted solenoid, those features began in 1937 production.
07-26-2017, 11:28 AM | #3 |
there isn't a dash button on my RHD '35, only a starter switch on the floor. I only have the start button on the floor, there is no dipswitch. may be something specific to cars made for your country?
07-26-2017, 01:28 PM | #4 |
My RHD 36 from NZ is as Brian said
07-26-2017, 03:07 PM | #5 |
The add on start button was a common retrofit with the solenoid ,Ted
07-26-2017, 04:42 PM | #6 |
07-26-2017, 04:52 PM | #7 |
Hi, it would be good to see pics of both cars, im interested because ive got a Dagenham built 1935 roadster. Am I right thinking the model 60 was just a model 48 with a 22hp engine in it?
07-26-2017, 05:12 PM | #8 |
Hi Weemark on holiday at the moment will post photos when I get home. The model 60 is basically a model 48 with the 4 mains v8 and lower gearing, although most of them were retrofitted with the later 22hp 3 mains v8 or 30hp engines
07-26-2017, 05:15 PM | #9 |
ok thanks for the info, look forward to the pics when you get home
07-26-2017, 07:44 PM | #10 |
Any dimmer switch other than the controls in the center of the steering wheel of a '35 or '36 is a post-production addition as is an instrument panel mounted starter button. I've had three RHD '35 phaetons and a RHD '35 convertible sedan (a mixture of very early, mid-year and very late production) and all were equipped with floor mounted starter switches and no separate headlamp dimmer replacing that in the center of the steering wheel.
07-27-2017, 01:19 AM | #11 |
Thank you all, I think you have answered my question, I will fill the hole in the dash and go back to original
Regards Viv. |
07-27-2017, 02:33 AM | #12 |
Yes as DavidG says. I have seen a lot of 35 RHDrives in Australia. If original unaltered the starter switch was on the floor and mounts to the top of the steering box. The high/low/park light switch control is in the centre of the steering wheel and the headlight switch is mounted under the steering box. Over the years many cars had more modern switching systems fitted. Original starter switches for the 35 are available NOS and they differ somewhat from the 33-34 versions. Regards, Kevin.
07-27-2017, 05:46 AM | #13 |
These 2 photos might be helpful. They show a pair of 1935 Ford Fordor Sedans with the Factory RHD Dash Panels. The top photo shows an Australian RHD Dash, while the lower photo shows an imported 1935 Ford from New Zealand. Australia never offered Mohair Interiors, but our local 35 Ford Sedans had Leather Seats. Notice the different locations of the Window Winders between the two cars. I hope that these pictures are helpful. Both cars also have the Aluminium Park Brake Extension. |
07-27-2017, 05:48 AM | #14 |
The "Dip Switch" was part of the Horn Button in the centre of the Steering Wheel on both of these cars.
07-27-2017, 06:07 AM | #15 |
Picture seems to be an Early 35. Door handle location. jmho kx
07-27-2017, 07:08 AM | #16 | |
On LHD '35's, the starter switch mounts to the top of the frame, and I would think it would be the same type mounting on RHD, but on the opposite side of frame.
07-27-2017, 07:24 AM | #17 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 07-27-2017 at 07:31 AM. |
07-27-2017, 07:43 AM | #18 | |
07-27-2017, 07:58 AM | #19 |
Yep The starter switch is on the frame unlike the 33-34s are on the steering box so my mistake there. Regards, Kevin.
07-27-2017, 08:05 AM | #20 |
JM35Sedan
On the subject of the E-Brake extender, the only one I have ever seen prior to Trevor's picture above was on a 35 Aussie Ute (The one that was in the former Ron Thorne collection if my memory serves me correctly), since then I have been wanting one for our 35 Aussie Ute, so it must be a "Down Under" adaptation.....quite clever and would love to find one!!! I was told by a fellow V8'er from there that they are difficult to find?? Maybe Trevor will speak more to the fact? |
