08-01-2011, 09:35 PM | #1 |
36 Ford engine update
I thought I'd give a little update on my 36.
After the burned valve change on the #2 cyclinder the compression is up. Had to cut the burnt valve out. Thank you David j for the donor valve!!!! Flushed the block and put it together. It ran, but I was still having problems with it running under load. Fast forward today. I sent my dizzy off to skip for a tune and coil rebuild, added some different plug wires, changed out the strom97 that had a crack for a good running holley94 and it's running well. Vacuum gauge read a little low at 15lbs but after upping the advance a couple tics I'm at a strong 18lbs. Oil pressure went up by 10 also with the extra vacuum. Although I'm running a 94 now I will be changing it over to the strom97 with the original air cleaner. Both will need work. Some video of it running. http://youtu.be/nXplV36R2GA https://www.youtube.com/watch?v=ZzvHR58a40k Thank you barners. Hope the pictures show up that i posted. Last edited by Tinker; 08-03-2011 at 08:48 AM. |
08-01-2011, 10:09 PM | #2 |
Re: 36 Ford engine update
that old motor sure sounds good!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
08-01-2011, 10:13 PM | #3 |
I took it out yesterday and ran it fairly hard and I think it did it some good. Couple more "responsible" hard runs and then I'll change the oil again and run the compression and vacuum tests again. One day at a time! Last edited by Tinker; 08-02-2011 at 08:43 AM. |
