02-08-2015, 09:43 PM | #1 |
Pumping gas pedal
You know sometimes when our are watching a procedure something doesn't look right but yer head isn't in the game. I watched a fellow try and start his A by pumping the gas petal. I'm thinking...hhhmmmmmmm.
in the middle of the night I'm up pumping does not add extra gas as there is no accelerating pump. Maybe the interruption of flow helps but probably the lose of a steady flow of fuel/air mixture is reduced. I'm getting slower that the speed of stink. Time to watch the Grammy's |
02-08-2015, 09:57 PM | #2 |
Re: Pumping gas pedal
It's possible that "pumping" the throttle plate while cranking the engine may set up oscillation in the fuel tube which MIGHT dislodge some obstruction to fuel flow. But the relief may be only temporary, and the effect would be more substantial using the choke similarly.
Joe K
Shudda kept the horse. |
02-08-2015, 09:59 PM | #3 |
If you think it is flooded you would hold the gas pedal down .
Pumping it does nothing but interrupt the amount of air that passes the venturi. |
02-08-2015, 10:11 PM | #4 |
I've seen a couple people not only pump the gas pedal, but they also pump the choke rod. I just grin and keep my mouth shut. They eventually get the engine started.
02-08-2015, 10:14 PM | #5 |
sometimes nerves cause that
or if you need to go to the bathroom Last edited by Mitch//pa; 02-08-2015 at 10:21 PM. |
02-08-2015, 10:17 PM | #6 |
Bingo !! maybe the guy forgot to take his medications
'31 180A |
02-08-2015, 10:21 PM | #7 |
It may help a slipping muffler belt!! LOL
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
02-08-2015, 11:47 PM | #8 |
it makes them feel good-----lighten up hahaha
Hotrods don't have valve covers |
02-08-2015, 11:53 PM | #9 |
Old habits die hard.
02-09-2015, 01:30 AM | #10 |
02-09-2015, 02:36 AM | #11 |
If that is the way they like to do it let it be. It won't hurt anything and it provides humor ! Why let it bother you ? Wayne
02-09-2015, 02:42 AM | #12 |
Not so sure about no damage.
I start an A with no throttle and full retard and a flick of the choke. If this dude was pumping the throttle he could have a lot of air and gas in the cylinders, and if he also is ignorant on starting procedures, he may also have the spark lever down. A full gutful of gas and air and spark advanced .....and then a back fire occurs.... Will be a nice shock to the bendix . |
02-09-2015, 10:57 AM | #13 |
pumping the pedal to activate the (non-existent) accel pump and holding the throttle open at a certain position to gain venturi effect are two very different things
'31 180A |
02-09-2015, 11:30 AM | #14 |
Even with modern fuel injected cars you don't have to pump the accelerator.
Unless of course, you want to get more air into the cylinders first to raise the compression to start the engine quicker..... |
02-09-2015, 11:40 AM | #15 |
Pumping the pedal is a clear sign that the person knows nothing about the model A .
02-09-2015, 11:41 AM | #16 |
on a fuel injected car if you hold it to the floor when cranking its in "clear flood mode" and will stop the injectors from spraying fuel
02-09-2015, 04:23 PM | #17 | |
Didn't anybody catch the humor in that? Like pumping the accelerator in a Model A to get more air into the cylinders? Too subtle eh? |
02-09-2015, 04:29 PM | #18 |
Venturi effect is going to be right about zero at cranking speed...
On an A or B, the choke is spring-loaded, meant to return to open when you release the knob. This is usually used briefly at first crank to get some gas moving up from float level to the available apertures and get the thing to fire. If engine is cold, the necessary enrichment is handled by an enrichment valve opened by rotating the choke knob...unlike most later cars with choke, the choke is not used for enrichment while driving cold because said valve handles that job and the choke itself is open as soon as you let go of it. |
02-09-2015, 04:43 PM | #19 | |
But opening the butterfly does raise compression when cranking the engine . |
02-09-2015, 04:45 PM | #20 |
"Unless of course, you want to get more air into the cylinders first to raise the compression to start the engine quicker....."
Rats, that is how you do it! All this time I have been holding a zip lock bag over the air intake to do this....wondered why it didn't work so good
'31 180A |
