Old 09-24-2019, 03:30 PM   #1
56yblock
56yblock's Avatar
Default vibration in my car
hello everybody, i have a new problem,
my car vibrates between 70 km/h and 80 km/h. where does it come from ?
56yblock is offline   Reply With Quote
Old 09-24-2019, 05:53 PM   #2
JimNNN
Default Re: vibration in my car
Under power or coasting?
Do you feel it mostly in the steering wheel, or is it more audible?
JimNNN is offline   Reply With Quote
Old 09-24-2019, 09:36 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
If there is steering wheel shimmy, you need a proper front end alignment.
If a driveshaft or torque converter is out of balance, they will cause vibration, but I would think you would feel it at much lower speeds continuously.
Old 09-25-2019, 02:03 AM   #4
Alaska Jim
Alaska Jim's Avatar
you may have lost a wheel weight. if you feel it in the steering , especially if it is mostly around 50-60mph. some times you can drive "out" of it, by going slower, or faster. check wheel balance before replacing any thing else.
Alaska Jim is offline   Reply With Quote
Old 09-25-2019, 05:00 AM   #5
56yblock
56yblock's Avatar
thanks for your answers guys, the wheels balance are correct , if i roll under speed 50, no problem, and above speed 60 too, it's beetween that the car got vibrations, i hope that you understand me...
Old 09-25-2019, 05:16 AM   #6
richard crow
check the u joints in the drive shaft look for rust at the caps or a lot of play in the joint
richard crow is offline   Reply With Quote
Old 09-25-2019, 07:11 AM   #7
ponymare
It could be the bushing in the rear of the tail shaft housing, but the driveshaft needs to be pulled to see.
ponymare is offline   Reply With Quote
Old 09-25-2019, 07:28 AM   #8
wellcraft17
I had a similar problem and it turned out to be the original brake drums were way out of balance, balanced the drums and problem went away.
wellcraft17 is online now   Reply With Quote
Old 09-25-2019, 04:11 PM   #9
50fordcoupeman
50fordcoupeman's Avatar
Could also be a cord separation or bulge in the tire tread or sidewall.
50fordcoupeman is offline   Reply With Quote
Old 09-25-2019, 06:41 PM   #10
Anteek29
Anteek29's Avatar
To start, I would focus on the u-joints.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-27-2019, 04:11 PM   #11
Jwawhite
Jwawhite's Avatar
Where can you find a shop that balances wheel drums??
I have the same situation as above, my wheels are balanced, my tires are fine, my u-joints are new, even the driveshaft is balanced.
I have not checked? the torque converter.
Jwawhite is offline   Reply With Quote
Old 09-27-2019, 06:19 PM   #12
Ford Freak
Jwawhite - I would think that probably an engine machine shop ( that balances flywheels , etc ) would be your best bet .
Ford Freak is offline   Reply With Quote
Old 09-27-2019, 06:58 PM   #13
scicala
scicala's Avatar
Some garages used to balance everything together by raising the tire off the ground on the car and spinning it with an electric motor and a balance ring attached to the wheel. I think this practice is long gone though.
Sal
scicala is offline   Reply With Quote
Old 09-27-2019, 07:04 PM   #14
KULTULZ
KULTULZ's Avatar
Post Re: vibration in my car
Related reading - http://forums.y-blocksforever.com/Topic146811.aspx
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-27-2019, 08:40 PM   #15
paul2748
paul2748's Avatar
Try a shop that balances big truck tires. These may still be balanced this way.
Sal
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-29-2019, 03:46 AM   #16
56yblock
56yblock's Avatar
i've checked the u joint and i don't have a play
Old 09-29-2019, 06:08 AM   #17
ponymare
U joints don't have to have loosness to vibrate, they can become dry and stuck and don't flex, one needs to remove the driveshaft and make sure each joint moves freely in both directions.
Old 09-30-2019, 12:51 PM   #18
rotorwrench
rotorwrench's Avatar
9 times out of 10, a resonant vibration at a certain rpm is tire related. A tire can be in balance and still cause problems. I check them by rolling them off the car to insure they roll true. When you find one that flops over after rolling a few feet then you know you found the problem. Tires take a beating. they get flat spots from setting too much. They can have an almost unnoticeable ply separation that will show up with problems like this.
Most towns used to have at least one shop that had a dynamic rotational balance machine that rotates the whole wheel, hub, & brake drum or rotor on the car to get it all working together. The machines are still available but are expensive. You see them more at front end shops than at tire shops.
Old 10-03-2019, 10:28 PM   #19
Jwawhite
Jwawhite's Avatar
Okay, having wasted time and money, I've come to the following conclusion:
I've seen each wheel on the car rotated while off the ground.
The front wheels were rotated up to 60 + MPH, one at a time by a machine with a roller, electrical motor. The LF tire rolled smooth, hand on fender no issues. When the RF wheel was rotated, it is obvious there is an issue, the RF fender was hopping.
The Operators opinion was the wheel is bent. I saw the lower inside wall of the tire with a wobble- I ALSO THOUGHT THE WHEEL WAS BENT.
I have American Classic Wheels and went over to Tire Pros where I bought them and stated the rim was bent. The wheel was removed and placed on a Balancer Machine and spun, the rim is not bent! Just what is happening, besides time and money?
Wheel was installed again and this time grabbed at 9 and 3 (just this Wheel off the ground) a good shake revealed worn out bushings at the Idler Arm.
Perhaps this is the cause of my wheel shake at speed....
Old 10-05-2019, 08:47 AM   #20
56yblock
56yblock's Avatar
i've checked the tires , it's look like not bad, they are just 3 years,i have the white walls tires ply, the car began to vibrate at last springtime and before is there not problem like this....
