06-25-2012, 02:32 PM | #1 |
31 roadster paint codes
Any do it yourself painters out there ? would like to use base coat , clear coat , and use original colars . if i could get a source for the codes i could have a local paint supplier mix it. Washington Blue would be the body color. Any help would be nice thanks The Hooch
06-25-2012, 02:46 PM | #2 |
Re: 31 roadster paint codes
06-25-2012, 07:24 PM | #3 |
Have you looked at any other old cars with base coat/clear vs enamel ??
06-26-2012, 02:39 PM | #4 |
enamel was not used on model a fords
06-26-2012, 03:14 PM | #5 |
And base coat clear was
06-26-2012, 06:15 PM | #6 |
06-26-2012, 06:28 PM | #7 |
Who says?? I believe you will find quite a few areas that alkyd enamel was used. Matter of fact, enamel was used WAY more than BC/CC was used!!
06-29-2012, 09:30 AM | #8 |
Model A standards answers all your questions about which paint was used and where, I'm just looking for the mix codes soas i can apply the proper color with todays paint someone offered a site, but the 31 roadster delux wasn't included in there info. So still asking the question Does any one know how to obtain the propper codes for 31 delux roadsters???
06-29-2012, 09:47 AM | #9 |
Call the Dupont Tech Line 1-800-338-7668. they will fax you any of the Model A paint codes. Not sure how close their code will be for your color, but you could get the code for a pint and try and match it to the Model A Paint Guide Chips.
06-29-2012, 03:42 PM | #10 |
Thanks for the number of dupont. that could be a start .
06-29-2012, 04:36 PM | #11 |
I am not a painter but try the link below that seem to offer everything and if nothing else have a full chip set biliary
http://tcpglobal.com/autocolorlibrar...FYeo4AodxxjGEQ |
