05-02-2024, 12:33 AM | #1 |
brake shoe
hello everybody, does anyone knows if the brake shoes are the same both front , rear on 1956 lincoln premiere ? thanks for help me
05-02-2024, 10:09 AM | #2 |
Re: brake shoe
'54 Skyliner. Restoration in progress. |
05-08-2024, 02:31 AM | #3 |
Re: brake shoe
the brake shoes front and rear look likes same to install .my question is :can i put the rear brake shoes in front wheel? or what the difference?
05-08-2024, 07:54 AM | #4 |
Re: brake shoe
When you say front and rear, are you referring to the front and rear axle or front (primary) or rear (secondary) brake shoe themselves?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
05-08-2024, 11:30 AM | #5 |
Re: brake shoe
yes rear and front axle, on shop manual it's a same reference
05-08-2024, 01:14 PM | #6 |
Re: brake shoe
The front brakes perform about seventy-percent of the vehicle braking and shoe sizes along w/ wheel cylinder diameter gives proper brake balance. The MPC does not give the shoe sizes so you would have to check your WORKSHOP MANUAL under BRAKE - SPECIFICATIONS. |
05-09-2024, 09:01 AM | #7 |
Re: brake shoe
This is still driving me up the wall -
KANTER gives two different sizes for shoes - https://www.kanter.com/series-178-br...make%3DLINCOLN 12X2 and 12X2 1/2 Are you able to call INTERNATIONAL on your cellphone and talk with them? It seems (to me) that the front shoes would be the wider but they give no further information. If able to contact, also ask the source of the shoes (CHINA). Brakes are somewhere you do not use box-store parts. |
05-09-2024, 08:42 PM | #8 |
Re: brake shoe
When in doubt, pull brake drums off one side, front and rear and measure and you will know. If all is stock and not been abused you can compare with what is available.
05-10-2024, 12:51 AM | #9 |
Re: brake shoe
That's the problem. It's SERVICE HISTORY and the car being in FRANCE.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 05-10-2024 at 12:57 AM. |
05-10-2024, 01:29 AM | #10 |
Re: brake shoe
KULTULZ that's the same references that i have on shop manual i think it's are same brake shoes front rear axle
05-10-2024, 05:33 PM | #11 |
Re: brake shoe
I don't know if you can make out the parts list I attached but the PN's for FRONT/REAR shoes are different.
If you have the LINC MANUAL, in the BRAKE SECTION at the end should be SPECIFICATIONS and sizing should be given there.
05-10-2024, 08:45 PM | #12 |
Re: brake shoe
Ahso, the plot thickens, did not know the subject was not on our shores. Will continue to moniter. Good luck to all in the know and attempting to assist.
05-12-2024, 03:01 PM | #13 |
Re: brake shoe
i found the brake drums measurments, the rear 12, front 12x 2,50, but nothing off the brake shoes ...
05-12-2024, 05:40 PM | #14 | |
Re: brake shoe
Let me make a phone call in the morning and I will get back.
05-13-2024, 12:19 AM | #15 |
Re: brake shoe
KULTULZ thanks you very much to help me
05-13-2024, 03:12 PM | #16 |
Re: brake shoe
OK ...
Just got off the horn with KANTER. https://www.kanter.com/i-30580646-19...make%3DLINCOLN His info source shows 12 x 2 1/2 FRT and 12 X 2 RR for a power assist drum car. He has the FRT SHOES in stock but does not have the rear as they order in batches and they haven't had the sell volume to re-order. He also has FRT and REAR HARDWARE KITS. The shoes are made in TAIWAN (better than CHI-CON SLOPPY COPIES), but the quality is unknown until you try to stop. There is no exchange core charge and that is another warning (to me). Now here is the thing, not only does the actual brake pad have to be a certain width, but the pad(s) will usually have different lengths for individual applications. This and wheel cylinder dia. gives proper brake balance on a 4-wheel drum car. That info will be part of the BRAKE SPECS that should be in the WSM. They are also bonded shoes which IMO is inferior to riveted linings as came from the factory. The trick here in the US is to have your shoes relined and you will be offered a choice of lining material as to how you want the car to perform. I am sure you don't have that option. Questionable also will be the quality of the brake drum and any hydraulic part you many need (IMO). TO BE CONTINUED - Last edited by KULTULZ; 05-14-2024 at 01:25 AM. Reason: THE USUAL |
05-13-2024, 03:37 PM | #17 |
Re: brake shoe
Another Source - https://www.lincolnoldparts.com/2000...t&fitment=1956
05-14-2024, 12:46 PM | #18 |
Re: brake shoe
i'll try to find someone to reliner the front old shoes, and i need to make to rectified the drums thanks for help
05-14-2024, 05:11 PM | #19 |
Re: brake shoe
You are welcome -
Here in the US you can have drums relined also. There must be the same service in EU. |
05-17-2024, 06:46 PM | #20 |
Re: brake shoe
Just as a point of interest, my 54 Ford customline shoes are same width front and back. But the front shoes have an additional hole in the side for a rear facing return spring. I did mine and must have put the fronts on the rear first cause I now remember those holes. When I did the fronts I simply drilled holes for that extra spring...was too lazy to re-do the rears as getting that little emergency brake clip in place is a real PITA.
