Old 01-16-2019, 08:35 PM   #1
MODELTR
Default Starter hums will not turn engine over.
Problem with starter humming and not turning over engine over was a weak battery. Many thanks to all for your help.It is very much appreciated !
Tom
MODELTR is offline   Reply With Quote
Old 01-16-2019, 08:39 PM   #2
MODELTR
Default Re: Starter hums will not turn engine over.
Problem was a weak battery. Not enough amps.Purchased new 825 amps battery. Problem resolved. Thanks to all for your help.It is very much appreciated !
Tom Rowe
Old 01-16-2019, 08:58 PM   #3
Gary WA
Gary WA's Avatar
Thanks for the update- Simple things first, Enjoy your A!
www.whidbeymodelaclub.com
Old 01-17-2019, 01:34 AM   #4
quickchange
quickchange's Avatar
bendix spring broken or bolt sheared off , or pinion drive on starter need light lube after cleaning , pull the starter & check it ,
quickchange is offline   Reply With Quote
Old 01-17-2019, 04:40 AM   #5
woofa.express
woofa.express's Avatar
I enjoyed looking at the photos. Great club.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 01-17-2019, 05:50 AM   #6
jm29henry
jm29henry's Avatar
6 or 12 volt system
jm29henry is offline   Reply With Quote
Old 01-17-2019, 08:36 PM   #7
Gary WA
Gary WA's Avatar
Thanks!
