Old 09-11-2010, 05:20 PM   #1
Maclab58
Maclab58's Avatar
Default 28 AR rear bumpers
The front bumper on my 28 Ar sport coupe does not have end bolts. I understand that this is correct for an AR. The rear bumper does have end bolts. My rear bumper needs to be rechromed but if they are not correct I want to find a pair of correct bumpers. Anyone know?
Maclab58 is offline   Reply With Quote
Old 09-11-2010, 05:27 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 28 AR rear bumpers
What engine number is your Sport Coupe?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-11-2010, 06:40 PM   #3
Steve Ciccalone
Steve Ciccalone's Avatar
Check to determine the length of the bumpers. If they are 60", they are Model T and not correct for your car. This was a common mistake made by many owners of early cars that thought they should be open end. There are two different versions of open end early rear bumperettes. These are almost impossible to find now and have to made from closed end units.
Also, I've seen dated photos from Nov 1927 showing early cars with closed end bumpers. Brent is correct in asking the number. Unless you have a three digit engine, I would recommend putting closed end bumpers on the car.
"A wet bird doesn't fly at night."
Steve Ciccalone is offline   Reply With Quote
Old 09-11-2010, 10:41 PM   #4
Maclab58
Maclab58's Avatar
my engine number is in the 60,000's march of 28. it has the odd AR characteristics, wheels, left side emergency brake etc.
Old 09-11-2010, 10:42 PM   #5
Rowdy
Most of that is likely correct for March. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-12-2010, 06:02 AM   #6
Steve Ciccalone
Parts on the very early cars literally changed within weeks at a time. Your car falls into the "early car" Feb-June section of the JS. I had a March tudor, a very original car, that had its original closed end bumpers front and rear.
Old 09-12-2010, 06:10 AM   #7
tuneman
tuneman's Avatar
I wonder where the car was assembled? There is also a chance that the higher engine number could be a replacement motor!
tuneman is offline   Reply With Quote
Old 09-12-2010, 10:36 AM   #8
1928ar
my march of 28 sport coupe's are numbers matching at 64120 and it had closed end bumpers on it and i had gottin if from the origonal owner
1928ar is offline   Reply With Quote
Old 09-12-2010, 01:22 PM   #9
Big John
Most likely you have T bumpers on your car... They only put open end bumpers on the 1st 200 cars...
Big John is offline   Reply With Quote
