Old 09-05-2019, 01:25 PM   #1
vern hodgson
Default Door dovetail
Purchased door bumpers etc for 29 coupe but may have the wrong one. Could someone take a close up photo of their door so I can see how it all fits in. I am looking at part#A61412B in macs catalog but the rubber I have is obviously , it is more of a U shaped block. Thanks
vern hodgson is offline   Reply With Quote
Old 09-05-2019, 03:50 PM   #2
kbinde2
kbinde2's Avatar
Default Re: Door dovetail
I have a '29 Coupe also, and have filed, sanded, heated, and cut more than a few of these bumpers trying to exact a fit that works, and looks halfway decent.
The photo is the drivers side, the passenger side is the "project" side.. alas,still minus bumper and metal strip. Good luck in your efforts, and if you find a solution, let me know.. I think the original assembly of the parts was before the door moved too far on the assembly line.! kb
kbinde2 is offline   Reply With Quote
Old 09-05-2019, 04:29 PM   #3
vern hodgson
Ok, so what does this assembly do? Does the brass insert fit tight to the dovetail when the door is closed, for alignment and to hold it from rattling.
Old 09-05-2019, 04:44 PM   #4
john in illinois
john in illinois's Avatar
The dovetail holds the door in position so it does not sag or rattle. as kb said,the new parts do not fit. I sand the flat part of the rubbers on a belt sander to fit. The strip originally was spring brass but is now soft. I use needle nose pliers to bend and force it in.
Mine is a 30 but are similar
John
File Type: jpg 02AABAC7-86BF-4340-A40E-8EE08D314D86.jpg (44.1 KB, 168 views)
Welcome each day
john in illinois is offline   Reply With Quote
Old 09-05-2019, 07:45 PM   #5
vern hodgson
These are the holes in the upper door on the coupe, what are they for? Second photo are original inserts I dug out of the dovetail.
File Type: jpg 6FBA8963-7A3B-4FE9-B9B3-0249CF3DCA05.jpg (36.4 KB, 105 views)
File Type: jpg D7461E07-79E6-4685-97B1-DEB0B65A687C.jpg (91.7 KB, 105 views)
Old 09-06-2019, 05:28 AM   #6
kbinde2
kbinde2's Avatar
If the photo is of the door frame towards the rear, there is a rubber anti-rattle bumper that would be there with two screws.. these rubber pieces should be in the kit that you purchased, you'll have to supply the patience to install all this.. none of the suppliers put that in the parts we buy.!!
Old 09-06-2019, 07:52 AM   #7
jb-ob
Vern,
Your photo questioning 'what are these holes for' shows a missing flat finishing plate that is screwed in place on the body, above the door.
Maybe someone with same coupe could post a picture of that area.
JB
jb-ob is offline   Reply With Quote
Old 09-06-2019, 12:05 PM   #8
vern hodgson
Originally Posted by jb-ob View Post
Vern,
JB
Can any one post a photo of what that bumper looks like, in place?
Old 09-06-2019, 12:38 PM   #9
Gary Karr
Gary Karr's Avatar
Here you go.
Gary Karr is offline   Reply With Quote
Old 09-06-2019, 10:11 PM   #10
vern hodgson
Ok, thanks Gary, looks as though I am missing a piece of trim above the door also
Old 09-23-2019, 02:16 PM   #11
peterknight
John
Thanks John. I have a '29 Sport Coupe and originally bought what Mac's said were the right parts but the metal clip is way too long. I then purchased what they said was for a 1930 and it's what you show in the photo. You have the rubber parts upsidedown compared to some recommendations but it works well this way! Thanks.
*** I actually found a source for parts that fit much better. They are Vintique A-702610-AS which I purchased from Smith and Jones Antique Auto Parts, 60 Wisconsin St., West Columbia, SC 29170. I'll try to upload a couple photos.
Last edited by peterknight; 09-29-2019 at 11:20 AM. Reason: Found source of better parts
peterknight is offline   Reply With Quote
Old 09-23-2019, 05:12 PM   #12
Bob C
Here's a picture Marco posted.
Bob
Old 09-25-2019, 10:25 AM   #13
peterknight
As John in Illinois pointed out, the available replacement metal pieces of the female dovetail are too soft. Does anyone know of a source of "springy" ones, or A MODERN REPLACEMENT for the dovetail?
Old 09-25-2019, 11:10 AM   #14
Gary WA
Gary WA's Avatar
I may have some!
www.whidbeymodelaclub.com
Old 09-29-2019, 11:31 AM   #15
peterknight
Attached are photos of the Vintique Parts I referred to in my earlier message.
Old 09-29-2019, 12:23 PM   #16
dmaxweb
dmaxweb's Avatar
Snyders has kits specific to year/model. Bought a set for my 30 coupe. Only required a bit of sanding of the rubber parts. Bit of silicone spray and clips popped in. Can't vouch for the 29 kit but very happy with the 30.
29 kit
https://www.snydersantiqueauto.com/ProductDetail
dmaxweb is offline   Reply With Quote
