04-02-2017, 06:18 PM | #1 |
Starting Problem
Hi, I have a 31 tudor that was my grandpa's car and been trying to get it started. I replaced all the wiring, the coil, and points but still no luck. When the engine turns over it does so very slowly. Do you think the starter is dead ?
04-02-2017, 06:22 PM | #2 |
Re: Starting Problem
hi james,welcome. i'm sure others will chime in,but in meantime use search about your problem.tons of info there. tom
04-02-2017, 06:27 PM | #3 |
Did you replace the battery cables? Late model cables are way to small for 6 volts. Pictures of your setup will help. Welcome, Gary
I am usually relatively happy------Gary |
04-02-2017, 06:39 PM | #4 |
Yes I did replace the battery cables, will post pictures
04-02-2017, 06:45 PM | #5 |
Read the voltage at the starter switch while the engine is being cranked.
04-02-2017, 06:49 PM | #6 |
04-02-2017, 07:27 PM | #7 |
Your car is fine. Quit buying parts and changing things around. Trouble shoot your ignition system and fix it. Join a local club and get the Les Andrews red book. Charge your battery and make sure you have he 6 volt cables.
04-02-2017, 09:54 PM | #8 |
Where did you buy the cables, and are you sure they are at least 00 ought? Also do you have a good grd wire to the engine. A good way is from tranny cover to the frame.
04-03-2017, 11:58 AM | #9 |
Make sure your battery is Positive ground.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-03-2017, 12:14 PM | #10 |
Change one thing at a time, then assess the result.
Be systematic. start a log of anything you do to the vehicle. This record should remain with the car. Look for a local source of advice, and join a local club. Bob |
