Old 04-08-2020, 06:04 PM   #1
fjz
Default aligning a 48 hood
I am looking for tips. The closest I have been able to get mine is a 1/2" gap. Have new hinges and support arms. I am aiming for a 1/8" gap but would be happy with a 1/4". All suggestions will be much appreciated.
fjz is offline   Reply With Quote
Old 04-08-2020, 07:41 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: aligning a 48 hood
Try this, loosen the 3 attachment bolts and rotate both sides in the same direction as far as they will go, tighten and check.
You may have to go in the opposite direction but this is a dance that you will have to do in order to get just the right spot.
Old 04-08-2020, 07:46 PM   #3
19Fordy
19Fordy's Avatar
Here's some info about the 40 hood that might help.
Worth a read.
https://www.fordbarn.com/forum/showt...40+sheet+metal
Old 04-08-2020, 08:07 PM   #4
woodiewagon46
If you can get a copy of the V-8 Times, dated May/June 2009, there is a detailed two page article on aligning the '41-'48 hood.
woodiewagon46 is offline   Reply With Quote
Old 04-08-2020, 08:13 PM   #5
Graeme / New Zealand
Graeme / New Zealand's Avatar
Here's an article about it . Might have to see if you can blow it up more.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-08-2020, 08:16 PM   #6
FortyNiner
FortyNiner's Avatar
The best reference is an article from the May/June 2009 V8 Times. Reprints are available through the Early Ford V8 Club.
What Woodie said.
Old 04-08-2020, 10:06 PM   #7
fjz
Thanks guys. Will try 51 merc's suggestion and attempt to enlarge Graeme's article which appears very detailed.
Old 04-08-2020, 10:29 PM   #8
fordor41
fordor41's Avatar
remember the more you raise the hinges on the cowl the lower the hood travels down
fordor41 is online now   Reply With Quote
Old 04-09-2020, 09:39 AM   #9
woodiewagon46
Like fordor41 states, every time you move one area, it affects another. If you read the article in the V-8 Times as I suggested you can get a better understanding as how it all works.
Old 04-09-2020, 05:14 PM   #10
corvette8n
corvette8n's Avatar
The V8 Times is available on a flash drive
https://shop.efv8.org/products/50-ye...es-flash-drive
Not only can you find the article on adjusting the hood, plenty of other articles on the '48.
Old 04-11-2020, 06:54 PM   #11
fjz
I checked v/8 times and flash drive but can not locate the 09 may june issue. Is there a way?
Old 04-11-2020, 08:16 PM   #12
woodiewagon46
If you can't enlarge the instructions that Graeme posted, I can copy it and send it to you by mail.
Old 04-12-2020, 12:32 PM   #13
fjz
Thanks for the offer Woodie. Graeme has emailed them to me and hopefully tomorrow when my office opens we can enlarge them.
Old 04-13-2020, 11:04 PM   #14
fordor41
fordor41's Avatar
Goggle "Mark Kicsak V-8 times". He has an article on aligning a '46-48 hood.
Old 04-14-2020, 05:12 AM   #15
FortyNiner
FortyNiner's Avatar
This is the article mentioned in several posts: https://www.earlyfordv8.org/forum/vi...81&sortby=desc
Thanks fordor41!
Old 04-15-2020, 08:39 PM   #16
fjz
Thanks FortyNiner. I clicked on the site you posted, now have it saved, and was able to read Mark Kicsak's article. Plan to get back at it again tomorrow.
Old 04-16-2020, 03:38 PM   #17
TJ
TJ's Avatar
If you go to the V-8 Club website you can contact the club members who sell the V-8m Club books. If they have the '09 back issue you need you can purchase it.
