11-27-2017, 08:21 PM | #1 |
Timing Gear Cover*New Pics*
Hello........is there a supplier that has new/used timing gear covers......the chrome one on Clyde has a hub that is way to small to fit the Generator.
Thanks in advance Last edited by Chevmn56; 12-09-2017 at 11:02 AM. |
11-27-2017, 08:52 PM | #2 |
Re: Timing Gear Cover
Could you post a picture of what you have??
Bob |
11-27-2017, 08:54 PM | #3 |
I have lots of timing gear covers. There is early & late. Let me know if you still need one
11-27-2017, 09:22 PM | #4 |
yep ill get them posted now the cover thats on it is chrome and the hub is small its a 29 motor if that helps ...in a 31 tudor with a Model B head and a 3 bolt pump.......i didnt change to this this is the way i bought it!
11-27-2017, 09:22 PM | #5 |
if you need a pic of the other side let me know... Thanks
11-27-2017, 10:19 PM | #6 |
I measured a cover and the generator mount is just a hair under 2" wide. Bob |
11-27-2017, 10:32 PM | #7 |
You could add a spacer or thick washers.
11-28-2017, 10:49 AM | #8 | |
11-28-2017, 01:41 PM | #9 |
I use an alternator & have a spacer & washers to make it right
V4f |
11-29-2017, 02:06 AM | #10 | |
11-29-2017, 07:43 AM | #11 |
I have a stack of timing covers. I would sell you one correct for your motor if you call me. 25$ plus shipping.
http://www.model-a-ford-4bangers.com/ |
12-08-2017, 09:04 PM | #12 |
Well I finally took the timing cover off, it does not look like a model A cover. The timing hole is in a elongated hub and the timing hole is at the top of the hub, when I lay the new/old timing cover from Berts on the mystery cover the timing marks do not line up at all....nowhere near each other. And the hub for the generator is obviously smaller (See Pics). Since I have the timing cover off I thought I would check the timing marks on the cam and crank gear and make sure they line up.
Welllllll !!!!! the cam gear has the dimple in it but, for the life of me i cannot find the dimple on the crank gear there is one tooth that has 2 small center punch marks in it, but it never lines up with the dimple in the cam gear (I rotated the engine over I bet 6 times) and yes it ran before see video(video is to big and wont load sorry). In all of my readings, in the Red book by Les and the service bulletins and judging standards......it’s all running together now, I thought I read somewhere that the crank timing mark should be the first tooth to the right of the key way?????? Is this correct???????? If so then the marks are good. The crank gear has some sort of lipped washer or something on the face of it so I cannot see anything that may be on the face of it. Thanks again for all your help |
12-08-2017, 09:17 PM | #13 |
Its a B timing cover , Not A , but A one fits , & can be used,
12-08-2017, 09:41 PM | #14 |
Here is a picture of the timing marks....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
12-08-2017, 10:31 PM | #15 |
I run a B distributor with an A cover and would trade if you were interested.
12-08-2017, 11:49 PM | #16 |
I wonder if the timing cover has been modified for some reason? The Model A and Model B generators are the same mount.
Charlie Stephens |
12-09-2017, 12:12 AM | #17 |
Don't worry about the cover lining up when you set the crank gear and cam gear timing marks. BTW your B cover shown will set the timing at 9 or 10 degree advance, so now is the time to install the correct A cover.
Once these 2 are clocked correctly, you install the cover and set the distributor timing by the pin in the cam gear dimple. Here's a picture of the gears in mesh. |
12-09-2017, 09:58 AM | #18 |
12-09-2017, 10:04 AM | #19 | |
12-09-2017, 10:10 AM | #20 |
Yeah I dont know on that I dont know enough about the A's YET......but upon clean up and wipe down the chrome cover generator mounting hub has Not bean ground down........maybe this is a B cover made for a alternator????? do the alternators use a narrower mounting hub?
