Old 04-13-2024, 10:41 PM   #1
TNTim
Default Helmet Distributor Issues
So I pulled my “37” distributor off the car. It’s a helmet, two bolt coil. Coil was recently redone by Skip. Car seemed to be running ok outside of not wanting to start when it got hot. I replaced the condenser. While i had it out, I checked the point gaps and it was way off. Driver side was over .020 and passenger was around .018. I put it on a Heyer/Ford machine. The Dwell % was very low too. So I decided to adjust the points to where I got 55% on driver side and total of 81% for both. Checked my timing on it and also on an KR Wilson box. Installed back on the car and now it runs rough. Pops when you give it a little gas.
My question is why would it run better at such a big point gap and low dwell?
TNTim is offline   Reply With Quote
Old 04-14-2024, 08:03 AM   #2
cadillac512
cadillac512's Avatar
Default Re: Helmet Distributor Issues
I don't understand the % figures for dwell. Do you mean degrees? If so, you should be in the 30's, not nearly so high. Your points gaps must be way too low. Generally gaps in the .016 range will work out very close to correct dwell numbers.
P.s. By the way, post this in the "early v8" forum and you'll get more info on early stuff.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-14-2024, 11:45 AM   #3
RKS.PA
RKS.PA's Avatar
As cad suggests, the early ford V8 forum will give you more feedback. I'm on both. Believe the point setting is .016. What is your timing set at and is the advance working??
Seems like you now can eliminate the condenser and the coil!!
RKS.PA is offline   Reply With Quote
