11-24-2021, 12:40 PM | #1 |
Will this work?
What causes this wear on each lobe?
11-24-2021, 12:46 PM | #2 |
Re: Will this work?
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
11-24-2021, 12:46 PM | #3 |
Re: Will this work?
Could the camshaft be moving forward ad back? Wrong or worn timing cover?
11-24-2021, 05:08 PM | #4 |
Re: Will this work?
It looks like low spots on the lobe where the parkerizing didn't wear off.
11-25-2021, 08:53 AM | #5 |
Re: Will this work?
The bottom of the lifter is not flat. As it comes to full lift it makes that wear pattern.
11-25-2021, 11:06 AM | #6 |
Re: Will this work?
L-100 regrind. Charlie ny |
11-25-2021, 12:32 PM | #7 |
Re: Will this work?
I think the radius of the bottom of the lifters is 68"
