10-14-2019, 07:02 AM | #1 |
Hub puller question
Bought this hub puller at Hershey - it has the raised letters "Ford AB Pat no. 1867211 " on it . I have searched the A and T forums as well as the web finding only 1 photo of a similar one which suggested it was for a T.
Does anyone know what this one is or made for ? It does fit the A rear hub . Thank you John Last edited by john_gto; 10-14-2019 at 12:36 PM. |
10-14-2019, 07:10 AM | #2 |
Re: Hub puller question
Pretty cool looking tool... Chap
10-14-2019, 07:50 AM | #3 |
The patent number you posted doesn't correspond to any similar device, but if at least the first 4 digits are correct, that would mean this device was patented around 1928-1930 – suggesting it's meant for a Model A.
10-14-2019, 07:52 AM | #4 |
I believe it will work on the '26-'27 Model T wire wheel hubs and on the early Model A hubs with the raised ribs.
10-14-2019, 08:48 AM | #5 |
Thanks for the comments so far - the patent numbers are difficult to read - the 8 could be a 3 and the last two 11 could be 77. I checked on a spare axle and hub and the thick lip at the bottom does fit nicely in the A hub groove. Trying to determine if it was made to be used on model A before using it on our 31 SWTS
10-14-2019, 09:40 AM | #6 |
Joe K
Shudda kept the horse. |
10-14-2019, 10:17 AM | #7 |
Those numbers didn't turn up anything. You can run the search yourself here, just enter the number with a 0 in front of it ("01867211"):
http://patft.uspto.gov/netahtml/PTO/patimg.htm |
10-14-2019, 11:10 AM | #8 |
I have one of those, it works great on my A's, check out the box.
-DAN |
10-14-2019, 12:07 PM | #9 |
Pretty cool item!
10-14-2019, 12:34 PM | #10 |
Thank you all ! Dan -nice to see the box it came in and the instructions. At $20 it looks like this was a good deal .
10-14-2019, 12:48 PM | #11 |
This puller was made by "Duro Metal Products Co" Chicago Il.
Patent 1,857,211. Applied for Feb 27 ,1931 and granted May 10,1932 |
10-14-2019, 01:35 PM | #12 |
The "Ford AB" lettering must mean "works with the Ford Model A or B." The B would have been out at the time the puller was manufactured.
10-14-2019, 06:41 PM | #13 |
That is likely so - Dan's puller has "Ford A" and "Pat Pend" from what I can see.
Thanks again everyone for your help! John |
10-14-2019, 06:49 PM | #14 |
Patent drawing
