01-05-2018, 07:42 PM | #1 |
Model a frame
Have a 1929 frame someone changed the front cross member to 30-31. I would like to go with 30-31.Will all components line up for 30-31, running boards, fender brackets , etc tall rad? steve
01-05-2018, 08:34 PM | #2 |
Re: Model a frame
You may have to drill a couple of bolt holes, but I think everything should line up.
01-05-2018, 10:24 PM | #3 |
Re: Model a frame
are the bolt holes for the body
01-06-2018, 04:45 PM | #4 |
Re: Model a frame
I think that I read somewhere that the late 29s had the new style cross member and that the factory added washers until the new radiators came out. If so then you may have the original cross member unless you can tell it was messed with.
01-06-2018, 06:45 PM | #5 |
Re: Model a frame
On Steve's site is everything you need to know about the frame and it's evolution.
http://www.plucks329s.org/frame.htm |
01-06-2018, 08:02 PM | #6 |
Re: Model a frame
