01-05-2013, 03:24 PM | #1 |
manifold heater
How good do manifold heaters work..i got one that fits original manifold.
01-05-2013, 03:34 PM | #2 |
Re: manifold heater
They put out pretty fair heat. The secret is to keep all other outside air out.
MIKE |
01-05-2013, 04:49 PM | #3 |
Re: manifold heater
Better than a candle. Dress warm. Folks were more rugged back then.
01-05-2013, 05:09 PM | #4 |
Re: manifold heater
I have an aluminum version that heats equivalent to a small candle. I also have a cast iron version that is somewhat warmer. While not the type that goes on an original manifold, I had an integral one piece heater manifold (forget the brand) that produced so much heat you had to close the butterfly door to a third on cold days!
01-05-2013, 06:25 PM | #5 |
Re: manifold heater
AUTOLITE. That's the way to go...HOT.
01-05-2013, 11:01 PM | #6 |
Re: manifold heater
01-06-2013, 01:57 AM | #7 |
Re: manifold heater
I have an Autolite heater. I would like to find a genuine Autolite door to go with it.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-06-2013, 03:41 AM | #8 | |
Re: manifold heater
Do you or somebody have a pic of it? Bill W.
01-06-2013, 06:02 AM | #9 |
Re: manifold heater
I have an Autolite heater on my waffle exhaust manifold and it heats up my Town Sedan very nicely!
01-06-2013, 09:49 AM | #10 |
Re: manifold heater
I put the cast iron Autolite with the waffle manifold on the phaeton many years ago. It has worked quite well, even on an open car.
01-06-2013, 11:18 AM | #11 |
Re: manifold heater
Although I haven't tried one, a heater on a stock manifold will definitely have limitations. The non-Ford manifold heaters include their own manifold with substantially more surface area to transfer heat.
http://www.abarnyard.com/ |
01-07-2013, 01:51 AM | #12 |
Re: manifold heater
No I don't. I have bought several of them and none fit it.
01-07-2013, 12:09 PM | #13 |
Re: manifold heater
I have a waffle type manifold heater on the Town Sedan. Once warmed up it throws out enough heat in the dead of winter to need the windows open. I take the scoop off during the summer.
Wayne @ Barb Malvern '19 T Speedster '26 T Touring '29 A Roadster '30 AA Stakebed '30 A Pickup '30 A Town Sedan '31 A Station Wagon '38 Columbia Girls bike (WWII) '40 Elgin Boys bike (WWII) '42 Super Deluxe Tudor '42 Willys MB Jeep '43 Willys MBT Trailer '43 M3A4 Hand Cart '43 Harley Davidson 42WLA with sidecar |
01-07-2013, 01:16 PM | #14 |
Re: manifold heater
01-07-2013, 01:33 PM | #15 |
Re: manifold heater
Are Autolite manifolds still available? I know that the scoops are from the normal suppliers, but what about the manifolds? If so where can one obtain one?
Dick |
01-07-2013, 02:49 PM | #16 |
Re: manifold heater
Swap meets and ads in various publications including on the ford barn.....usually the manifold will need to be planed and checked with a straight edge,,,,,,, they can be found.... keep looking.. i have not seen that were being reproduced.....
01-07-2013, 02:50 PM | #17 |
Re: manifold heater
MIne works well, Just an add on on top of the original muffler. In the summer, I plug the forward end with a wad of aluminum foil, Keeps the air from heating the firewall door. John
01-07-2013, 03:32 PM | #18 |
Re: manifold heater
Which supplier would that be?
01-07-2013, 04:43 PM | #19 | |
Re: manifold heater
Snyders??
01-07-2013, 06:13 PM | #20 |
Re: manifold heater
Bratton's #13670
