01-07-2018, 01:17 PM | #1 |
36 Ford Oil Filter
I'm considering adding an oil filter to my 36 Flathead. This appears to be the correct unit. Is it a one shot filter; i.e. you discard after an oil change? It doesn't appear to have a cartridge.
01-07-2018, 05:55 PM | #2 |
Re: 36 Ford Oil Filter
that one goes in your display case of ford nik nacs. you need the later one with a replaceable cartridge. more common on 40 48 motors and it will bolt on your heads. or, after market that bolts to the fire wall. not 8ba 49 and up, different bolt pattern.
01-07-2018, 06:17 PM | #3 | |
If authenticity doesn't matter then I tend to agree with the second post - install the later filter housing on the left cylinder head. It utilizes a common "throw away" cartridge.
01-07-2018, 11:33 PM | #4 |
And put the box on display along with the filter. Harder to find the box than the filter.
Alan |
01-08-2018, 08:14 AM | #5 |
WGreeley, If you are planning on adding a functional oil filter then go with a later unit with replaceable filter. If you are going with authenticity, then there is a problem. Your unit was not available in 1936. You have a later replacement filter. The 1936 version of this filter (51-18662) had an inlet fitting on one end and an outlet fitting on the other end. A new additional filter (74-18662) with a dual inlet/outlet fitting on one end was introduced in 1937 to fit the new 60 hp engine. In 1938, both filters were replaced by (1) new filter (51-18862-B). It had dual fittings on one end and a single fitting on the other end. One of the fittings was sealed with a pipe plug allowing you to choose the 60hp or 85hp configuration.
01-08-2018, 11:12 AM | #6 |
01-08-2018, 12:21 PM | #7 |
Yes, The entire filter was thrown away. These canisters were used on many brands of vehicles during this time period. I have no specific info on how often to change them. Ford literature says to change the filter regularly!!
01-08-2018, 06:14 PM | #8 | |
