07-01-2012, 03:22 PM | #1 |
Model B pan
Is there any trick to remove the rear section of a B pan so it can be used with an A flywheel housing?
07-01-2012, 04:02 PM | #2 |
Re: Model B pan
Its held on with some spot welds You could try a spot weld removal tool or
if your careful with an air chisel John Cochran |
07-01-2012, 06:24 PM | #3 |
Re: Model B pan
I cut mine and left a strap shaped piece on the pan rather than risk leaks.
Charlie Stephens |
07-02-2012, 12:22 PM | #4 |
Re: Model B pan
PM sent
07-02-2012, 04:25 PM | #5 |
Re: Model B pan
