08-09-2022, 01:13 AM | #1 |
Rebuilding Zenith Carburators
Over the last 10, or so years I have rebuilt at least 50 zenith carburetors. I started out with a couple of plastic 5 gallon buckets of cores I got in a trade of parts. I started out by taking each core apart, and disassembled. I used lacquer thinner, then Rust Sol to start the cleaning process.
I then used the Judging standards, and a series in the Restorer to ID each carburetor, matching up tops to bottom castings and mixed Holley, and Zenith as needed. I cleaned each circuit, even removed the brass plugs to eliminate plug ups. So far, I haven't needed to rebush a throttle shaft, or reseat the GAV. I test ran quite a few on my car in order preset the idle, now I just preset the idle Here are the before and after pictures of my most recent rebuilds. I made a youtube video about dissasembling the carbuerator https://www.youtube.com/watch?v=T1oQSv-oQQc |
08-09-2022, 08:32 AM | #2 |
Re: Rebuilding Zenith Carburators
Nice.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
08-11-2022, 04:21 PM | #3 |
He does really nice work. I have his carburetors on my model a’s. No problems with them they start right up. I highly recommend him.
08-11-2022, 07:09 PM | #4 |
I am new to model As and my introduction is through a pretty much basket case AA that probably should have been a parts truck but my ignorance has gotten me in too deep to turn back now. I have completely rebuilt everything mechanical on chassis and still waiting on machine work on block to complete. Truck came with a Tillotson carb in pretty good shape but I wanted a Zenith. I finally got it done but it was a learning experience. I flow tested all jets and set float and leak tested. May be a while before I can run test.
08-11-2022, 08:13 PM | #5 |
Nice! They look too good to put on a car!
08-14-2022, 05:54 PM | #6 |
