03-05-2022, 09:20 AM | #1 |
Followup To Engine Removal Preference
My preference was to take the engine, flywheel, clutch & transmission in one piece out from the front. It's a done deed, and it went very well. Preparations included: >Jacks (2) to support front wheels about 6" off the floor; >Front bumper, headlight bar & radiator off of the car; >Hood off; >Front floor boards out; >Stock rear engine mounts in place & radius rod joint disconnected; >Clutch & brake pedals off; >Accelerator assembly off: >Transmission in neutral & gear shift off; >Chock in front of a rear wheel; >Manifolds off & exhaust tied up; >U-joint housing off & torque tube supported with a jack stand. Used an engine hoist with a single hook in #3 spark plug hole & 3 people. One fellow worked the hoist, one guided the crankshaft pulley over the front crossmember, and the 3rd guy guided the transmission past the firewall. The workers are 70, 79 & 80 years of age.
Bob Bidonde Last edited by Bob Bidonde; 03-05-2022 at 09:28 AM. Reason: Delete duplicate post |
