03-04-2022, 12:59 PM | #1 |
Balance weights moving
Balance weights moving is it possible for the balance weights on a 32 engine that a full circle weights to move in cause a slight vibration
03-04-2022, 01:11 PM | #2 |
Re: Balance weights moving
Originally they were pinned, and had a tight shrink fit
03-04-2022, 01:23 PM | #3 |
rvye, Do you know who fitted the counterweights? If not, we have no idea how well they were fitted and I think it unlikely they would move if they were done well. Also, what is a slight vibration? I had one in which my wife had to tighten her bra straps.
03-04-2022, 01:33 PM | #4 |
You look at the picture close the balance weight has two marks on the crank into marks on the weight and they don’t line up I wonder if that’s the amount that it has moved
03-04-2022, 03:50 PM | #5 |
The only way to know for sure is to have it checked for balance.
We used to spot weld the cranks pins (pressed together) in our road racing Yamahas. |
03-04-2022, 04:39 PM | #6 |
03-05-2022, 11:44 AM | #7 |
Take a hammer and punch and see if the full circle weight will move.
