03-01-2022, 07:06 AM | #21 |
Re: 1929 Model A leaking gas
All the different varieties of Model A carburetors are pretty simple and easy to work on. You should have no problems but you need to do a little reading.
Here are a couple handy references for the Zenith carburetor: http://modelabasics.com/carberutor.html https://model-a.org/default.html
03-01-2022, 10:52 AM | #22 |
03-01-2022, 10:58 AM | #23 | |
Wow this is great, thanks. Cheers |
03-01-2022, 11:20 AM | #24 |
That was 2 or 3 years ago, so hopefully they still have the same stock.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 03-01-2022 at 11:20 AM. Reason: Oops |
03-01-2022, 01:25 PM | #25 |
I ALWAYS shut the gas off when I park my car. EVEY old timer that I talked to in two different Model A clubs told me the same thing. It definite does NOT hurt to turn it off and can prevent leakage and potentially maybe even a fire.
03-01-2022, 02:02 PM | #26 | |
The carb really needs to be looked over. Right now I am just trying to acquire information. Eventually will learn something I hope Cheers |
03-01-2022, 04:07 PM | #27 |
So I have this carburetor, and it is leaking badly at this spot.
Can anyone here tell me what make it is so I can a rebuild kit. I don't know about Model A, but if I had to guess the float has a whole in it and sunk so the carb is running overfilled with gas, I wonder how it manages to run http://countrystaycation.com/2.jpg http://countrystaycation.com/3.jpg http://countrystaycation.com/7.jpg http://countrystaycation.com/9.jpg |
03-01-2022, 04:22 PM | #28 |
Zenith.
Easy to work on. |
03-01-2022, 04:32 PM | #29 |
03-02-2022, 11:36 AM | #30 |
Have you tried the "tapping on the side of the carburetor" trick?
If that stops the leak it's an indication the the float valve needs attention.
03-03-2022, 07:46 AM | #31 |
Zenith style carburetors were made by other manufacturers but they are all the same and all take the same parts.
03-03-2022, 10:07 AM | #32 | |
the gasket around the float valve can sometimes leak then over filling the bowl. you can check that buy using a glass jar tied to the top part of the carb. also when you order your carb parts order the little gaskets that are used to shim the float valve to adjust the float level.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
03-03-2022, 01:04 PM | #33 | |
Cheers |
03-03-2022, 02:14 PM | #34 |
Inspect your replacement parts. This main jet was cracked causing me to deal with a leaking carb for years.
03-04-2022, 12:52 PM | #35 |
03-04-2022, 08:12 PM | #36 |
[QUOTE=WHN;2109053]As Bill Williamson said many years ago. They all leak, that’s why there is a shut off.
Gravity feed! May not leak today, but just give it a chance. i think this is wrong. it should not leak. i have a rototiller, gravity feed carb with a float valve to shut off the gas i have a snow blower that has a float valve to shut off the gas. i have a lawn mower that has a float valve to shut off the gas. surprise ! none of the pcs of equipment have a gas leak and i have a model A ford that does not leak gas out of the carb. if your model A is leaking gas out of the carb you didn't fix it correctly.
03-04-2022, 09:17 PM | #37 | |
[QUOTE=old ugly;2110209]
Why do you think the manufactures put the shut off valves there? Enjoy. |
03-04-2022, 09:37 PM | #38 |
I agree one should use the gas shut-off when parking the car, but a properly re-built carb also should not leak by itself. I bought a re-built carb many years ago and it has never leaked a drop….even when I forgot to turn the gas valve off.
03-05-2022, 11:05 AM | #39 |
My riding lawn mower never had a gas shut off valve, I had the mower for years and never had a problem until one time when I did a routine maintenance, including changing the oil in the engine. The next time I went to use the mower it wouldn't crank over, both the crankcase and the cylinder were full of gas. It now has a shut off valve, lesson learned.
03-05-2022, 11:15 AM | #40 | |
[QUOTE=WHN;2110228]
the fuel shut off at the tank has another important use. it is there to shut the fuel off to the engine so you can fix your carburetor properly. that is why i think it is there. shutting that tank valve off is probably a good idea while the car is park for extended times. but, i would not trust it. they can leak too. so if that leaks and your carb leaks you have not solved any problems. another thing if that carb is leaking when the car is not running that means it is also leaking when the car is running. if it is dripping on the ground, you maybe ok with that but if it is leaking internally you will never make that engine run correctly.
