Old 10-15-2015, 04:22 PM   #41
Vin-tin
Vin-tin's Avatar
Default Re: Welding in Patch Panels on a Cowl
Originally Posted by Terry, NJ View Post
Kevin, You're one of the last people on here I want to debate with over anything, But I want to point out that heliarc is merely TIG with a different gas. The equipment is the same (Cups, handle, Tungsten electrode,variable power through either a footswitch or thumbswitch) but most welders use the 25% argon, 75% CO2 mix for costs. We used the gas interchangeably for aluminum and steel. The only the we changed was the polarity, AC with high freq. start for aluminum, IIRC. It's been a while. I agree with you on every other point.
Terry
Does that give a better, more workable weld on steel sheet metal than straight argon?
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 10-15-2015, 04:47 PM   #42
Terry, NJ
Terry, NJ's Avatar
My best answer! I don't know! In the three or four welding shops I worked in, I can't ever recall anyone using helium($$$) or straight Argon. The only thing I ever saw used was the75% CO2 and 25% argon, for MIG or TIG. Actually, since it's merely shielding the welding from oxygen, I don't what part the argon plays. Likewise, in the low Hydrogen wires like 7018, 8018, etc, the flux creates a shield to keep hydrogen out of the weld. Hope this helps!
Terry
Terry, NJ is offline   Reply With Quote
Old 10-15-2015, 05:14 PM   #43
pooch
pooch's Avatar
Strange that here in OZ, our MiG gas composition is the other way around.
For thin metal, we have 3.1 % oxygen, 5 % CO2, rest is argon.
For a bit thicker plate, it is 20 % CO2 and 80 % argon.
These are BOC specs.
I seem to remember our general MiG gas was something like 90 % argon and 10 % CO2.
I wonder why USA is so much higher in CO2 ?
pooch is offline   Reply With Quote
Old 10-15-2015, 05:30 PM   #44
Rex_A_Lott
Cost. CO2 is much cheaper than Argon here. There are several mixes out there, mostly for MIG, depending on what you are doing. 75% Co2 an 25%Argon is the most common for general purpose Mig work. I personally have never see a mix for doing TIG, with everybody sticking to 100% Argon, but that may just be because of convenience and because my experience is limited.
Hell, when I learned there were only two types of Tungsten, and I have definitely not kept up to speed on what is going on out there now.
Rex_A_Lott is offline   Reply With Quote
Old 10-15-2015, 06:24 PM   #45
pooch
pooch's Avatar
Argon must be much harder to get out of the air.
It is in abundance compared to CO2.
23.8 times more .
The common name air is given to the atmospheric gases used in breathing and photosynthesis. By volume, dry air contains 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases.
Atmosphere of Earth - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Atmosphere_of_Earth
Old 10-15-2015, 06:52 PM   #46
tbirdtbird
you can use regular Ar/CO2 to MIG SS but if you want really nice welds with SS wire there is a mix with some He in there.
There are other combos for similar reasons with other metals
Some of the gasses are also chosen to stabilize the arc, not just shield from air
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-15-2015, 07:23 PM   #47
Rex_A_Lott
Where I work we used 100% Argon to MIG stainless, to get rid of the black look. The welding gas rep had a tri-mix they recommended, but the boss wouldnt buy it because we did this so very little.
Some of the tri-mixes had O2 in them, which seemed ass-backwards to me, since the O2 was what you were trying to shield out, but I was not an expert.
Old 10-15-2015, 08:09 PM   #48
Ron W
Ron W's Avatar
I learned to "Heliarc" in 1960 while working in a small "job" shop. We built machines and parts for the electronics development industries. We did a lot of development for Raytheon and Sylvania. After a few years I started my own small shop. I closed my shop about three years ago. During that time I used straight argon on my "tig" welder. The reason is that although a mix with co2 will do slightly better on steel, you don't want any co2 on aluminum (which we did a lot of). That way we only had to have one type of gas on hand. I am certainly not a expert, but that worked well for a long time. The last few years I have been doing some metal shaping as a hobby. I too have come to prefer the butt weld with TIG but I also like the A/O torch with RG 45 rod. The weld is much softer and can be stretched easily. Ron W
Ron W is offline   Reply With Quote
Old 10-16-2015, 12:03 AM   #49
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Model A Fan View Post
Uhhh, how much are yours?
Just pay the man! they will save you hours and hours of time and frustration.
Old 10-16-2015, 06:49 AM   #50
Kevin in NJ
The welding gas mix you need depends on what weld structure is required.
Better penetration, less porosity.....
Welding gases for mig
Welding gases another site
Kevin in NJ is offline   Reply With Quote
Old 10-16-2015, 07:18 AM   #51
Terry, NJ
Terry, NJ's Avatar
Thanks for posting this! With all the talk about CO2 and global warming, it's a fun fact to know that CO2 is less than 1%, less than .5 of 1%. Better quit here before it gets political!
Terry
23.8 times more .
Old 10-16-2015, 07:49 AM   #52
Flop
Vin tin you can't use 75 25 mix with a tig . Leaves pits in the weld .
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 10-16-2015, 07:51 AM   #53
Flop
Bills panel welded in
412 867 1659
[email protected]
