07-07-2013, 05:42 AM | #1 |
Starter motor on 12 volts.
My 40 coupe has 12 volts and the original 6 volt starter..it works a treat, but I'm wondering if I should be aware of any potential issues.I would like to sort any problems before they arise and leave me bump starting it out on the road somewhere.Will the starter motor need upgrading or replacing, if so what's the plan?
Thank you . |
07-07-2013, 05:49 AM | #2 |
Re: Starter motor on 12 volts.
Been running my 6 volt starter on 12 volts for over 15 years no issues.
There have probably been as many problems when running on 6 volts as there ever were on 12 volts.
07-07-2013, 06:27 AM | #3 |
You might want to have a starter drive spring on hand, I have broken a few with 12 volts. Easy fix, and everything else is ok.
07-07-2013, 09:11 AM | #4 |
07-07-2013, 09:25 AM | #5 |
Thanks fellas.....
07-07-2013, 09:30 AM | #6 |
07-07-2013, 09:45 AM | #7 |
The thing I notice most on my F1 are the quick starts even after having set for awhile. The starter is used less therefore should compensate in part for the higher voltage.
Son, you will never blow an engine up in high gear. |
07-07-2013, 09:50 AM | #8 |
Nothing like the sound of a Flattie starter....was watching an old movie on TCM last week, heard a Flattie starter off camera...next scene up drives a 40 Woodie
07-07-2013, 10:55 AM | #9 |
I agree the sound is special..but the quick zap of the 12 volts through the starter and easy starting more than compensate....previous cars Ive had always had me wondering if it was going to fire on 6 volts.
