Old 08-18-2022, 06:00 PM   #21
cas3
Default Re: Remove 1 ton rear brake removal
Its probably similar to what I have here, "Sil-Glyde" , a napa product kinda like vasolene but silicone based I assume. Good stuff to have around.
Old 08-18-2022, 06:23 PM   #22
expavr
expavr's Avatar
Originally Posted by madspeed View Post
2 3/8 sound correct?
That's correct. See attached photo of Ford OEM socket
expavr is offline   Reply With Quote
Old 08-18-2022, 06:27 PM   #23
expavr
expavr's Avatar
Attached are the pages from the 1939-48 Shop Manual that describes the procedure for removing the Brake Drum and resetting the loading on the bearing after the removal. My apologies for the upside down page 2 image.
Old 08-18-2022, 06:30 PM   #24
35fordtn
35fordtn's Avatar
https://www.summitracing.com/parts/wmr-w83241
This is the socket needed
Old 08-19-2022, 10:40 AM   #25
GB SISSON
GB SISSON's Avatar
I looked for the piece of the cardboard box with the seal #, but couldn't find it. I remember it covered a lot of years.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
GB SISSON is online now   Reply With Quote
Old 08-19-2022, 11:05 AM   #26
madspeed
Thanks guys, you've been a big help. I was able to pull everything apart and get the needed part numbers from the wheel cylinders. Have all new wheel cylinders and flexible lines ordered as well as a new master cylinder. hard lines look to be in good condition, but I may blow some brake cleaner through the lines to get out any gunk that may be in there. Time to get cleaning and painting! I may order one of the bearing sockets to ease in the assembly but I was able to remove the nuts with a slight tap and a punch.
madspeed is offline   Reply With Quote
Old 08-19-2022, 11:17 AM   #27
madspeed
@expavr, Thank you, those scans helped with my question about tightening the hub. I did order myself a copy of the manual for future use.
I see that Fel Pro makes rear axle gaskets, but their online parts ID system only goes back to 1960 vehicles. Anyone have a part number for them?
Old 08-19-2022, 11:43 AM   #28
cas3
Those gaskets for the axle shafts are darn near universal. If you have local parts store with some in stock for nearly any 3/4 ton pickup axle, like a modern dana 70 or dana 80 they might fit. bring a paper tracing along with you, or just make them
Old 08-19-2022, 11:54 AM   #29
madspeed
great idea. I have one that's in decent enough condition, I'll take it to Napa and see if it will mate up to something they have.
Old 08-24-2022, 11:55 AM   #30
madspeed
Got her all cleaned up and ready for installation.
Old 08-24-2022, 11:57 AM   #31
madspeed
Looking to replace these axle end to hub gaskets but not finding anything in the shop manual. Anyone recognize?
Old 08-24-2022, 12:12 PM   #32
Bob C
I think the part number is 61-1144.
That gasket looks home made.
Did some more searching and Ford changed the number to A8TZ-1001-B,
old NAPA # J26253, Fel-Pro 2931. Looks like most parts housed have them.
Bob C is online now   Reply With Quote
