Old 03-04-2022, 12:59 PM   #1
[email protected]
rvye@roadrunner.com's Avatar
Default Balance weights moving
Balance weights moving is it possible for the balance weights on a 32 engine that a full circle weights to move in cause a slight vibration
File Type: jpg 82555BEA-1F7A-4CA9-82B5-E76FC09C3260.jpg (46.8 KB, 86 views)
rvye@roadrunner.com is offline   Reply With Quote
Old 03-04-2022, 01:11 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Balance weights moving
Originally they were pinned, and had a tight shrink fit
Old 03-04-2022, 01:23 PM   #3
Synchro909
Synchro909's Avatar
rvye, Do you know who fitted the counterweights? If not, we have no idea how well they were fitted and I think it unlikely they would move if they were done well. Also, what is a slight vibration? I had one in which my wife had to tighten her bra straps.
Old 03-04-2022, 01:33 PM   #4
[email protected]
You look at the picture close the balance weight has two marks on the crank into marks on the weight and they don’t line up I wonder if that’s the amount that it has moved
Old 03-04-2022, 03:50 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
The only way to know for sure is to have it checked for balance.
We used to spot weld the cranks pins (pressed together) in our road racing Yamahas.
Old 03-04-2022, 04:39 PM   #6
[email protected]
We did the same thing on the 650 Yamaha snow pro sled that we raced years ago
Old 03-05-2022, 11:44 AM   #7
katy
katy's Avatar
Take a hammer and punch and see if the full circle weight will move.
