Old 09-26-2019, 06:45 PM   #1
Ford coupe
Default Torque
Torque for rear axle nut on 36 ford car???
Ford coupe is offline   Reply With Quote
Old 09-26-2019, 07:04 PM   #2
Talkwrench
Talkwrench's Avatar
Default Re: Torque
A Lot! You'll pucker its over 200lbs...
This is what I do. Make sure your taper is clean, no grease or anything between the surfaces [others may go into detail about matching the surfaces] nice clean and square keyway. I only have a torque wrench that goes to 150lbs so I go all the way with that , then go to the next cut in your castle nut. If you can go further than that youre a better man than me.. Good luck!
Old 09-26-2019, 07:35 PM   #3
Tinker
Tinker's Avatar
Default Re: Torque
If you get up to 180 or just north of it, you'll be fine. It can make one a bit nervous to torque something that is as old as it is and not think it'll not strip out.
Old 09-26-2019, 08:48 PM   #4
meric42
meric42's Avatar
Default Re: Torque
I'm with Tinker, 180 then align to the next cotter pin slot
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
