Old 05-04-2019, 03:10 PM   #21
quickchange
quickchange's Avatar
Default Re: How’s your Shortened pitman arm working?
We have had made the RIGHT HAND DRIVE version made by the same folk who produce the LHD one , So if you need a RHD one we can supply , [email protected] also available from Arizona Model A, I smell salt ?
quickchange is offline   Reply With Quote
Old 05-04-2019, 06:31 PM   #22
Sideline
I’m using one with my newly rebuilt 2 tooth box and I wouldn’t go back.
Three turns from center to lock either way and I can steer with one hand now. I haven’t noticed any difference in turning radius.
Sideline is offline   Reply With Quote
Old 05-04-2019, 08:44 PM   #23
CarlG
CarlG's Avatar
I have the short pitman arm, am using it with an F100 steering box. No difference in the turning radius, much easier steering while under way.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-04-2019, 10:31 PM   #24
31a
Installed one on my 29 station wagon it makes a difference have 5 other A's will upgrade those eventually
31a is offline   Reply With Quote
Old 05-05-2019, 12:16 AM   #25
updraught
updraught's Avatar
Mac's says:
Steering Gear Ratio 1928-29, 11-1/4:1
Steering Wheel Diameter 1928-29, 17-1/2"
Pitman Arm Length 6-7/8" hole center to ball center
Steering Gear Ratio 1930-31, 13:1
Steering Wheel Diameter 1930-31, 17"
I gather 1932 is 13:1 and 33/34 is 15:1 .
"Factory production Ford F-100 pickups were equipped with “Armstrong” power steering in the form of a 17.5-inch steering wheel and 16 to 1 steering gear ratio."
http://www.classicperform.com/tech_a...r-Steering.htm
So if you add a shortened pitman arm it must be about 17:1
updraught is offline   Reply With Quote
Old 05-05-2019, 09:20 AM   #26
katy
katy's Avatar
Originally Posted by BillCNC View Post
What is the length between the centers on the shortened Pitman Arm's?
Regards
Bill
Bratton's listing says that it is 1.5" shorter than stock.
https://www.brattons.com/new-one-pie...ed-pitman.html
Old 05-05-2019, 09:47 AM   #27
whirnot
whirnot's Avatar
I put one on my 29 roadster, and it definitely steers easier. There is a wider turning radius with the seven tooth box, but it's worth it. Between that and the Mitchell transmission, now my wife can drive it.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-05-2019, 09:56 AM   #28
duke36
The shortened arm depending on length pulls the drag link up and can allow more clearance to the tie rod depending on front spring condition and travel.
Old 05-05-2019, 03:39 PM   #29
wensum
wensum's Avatar
Clearly your roads must be a lot straighter than ours, with lots of tight bends, sometimes consecutive, the effective lower ratio caused by the shortened arm results in one having to turn the steering wheel more than originally to go around a corner.
The steering may be lighter but the extra twirling of the wheel can be wearying?
Also, I found that one needed to fit an adjustable drag link to get full lock on both sides.
Fitting the 5.00 radial tyres has made the steering on our car beautifully light with the original length pitman arm.
wensum is offline   Reply With Quote
Old 05-05-2019, 05:49 PM   #30
Sideline
Not on mine.
Old 05-06-2019, 01:17 AM   #31
M2M
M2M's Avatar
Uh-huh, I knew there must be a down side.
M2M is offline   Reply With Quote
Old 05-06-2019, 04:31 AM   #32
SAJ
SAJ's Avatar
I get full lock on both sides on my 1930 RHD Roadster. This is both with the original 7 tooth box and the 2 tooth I fitted to replace it. I have 550 X 19 Excelsior Stahl radials. Full lock means contact with the steering stops both ways. This depends on how long the stops are and whether a spring washer is fitted to them. I have read that the 550 radials can contact a brake rod one one side or the or the other too,limiting the lock. This does not happen on my Roadster.
I like the lighter steering and do not particularly notice more wheel turning in bends.
I also have a 1931Tudor with standard Pitman arm to compare it with. I may try a shortened arm on that too, because 2500 miles on a rally last week was quite an arm work-out with the higher ratio steering.
Wensum has a speedster which must be lighter and need less turning effort I think. We both travel the same roads here in NZ and he has Stahl radials too, though he says 500 X 19.
I did not have to fit an adjustable drag link and my wheel is centralised.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 05-06-2019, 05:19 AM   #33
quickchange
I run one on my delivery LHD & liked it so much decided to have new RHD ones made , I also love my LHD F100 box , Mitchell gear splitter, & the wife ,
Old 05-06-2019, 11:10 AM   #34
M2M
M2M's Avatar
Are there different length shortened new pitman arms sold by the suppliers?
I plan to fit bias ply 5.50x19 tyres to the front; sounds like I may have contact problems.
